Confused.... Help Please!
Results 1 to 32 of 32
    Sep 2010
    Hi Guys,
    According to the manual, the "BUTTON" function acts as a "GOTO" to a defined label (the last argument) with the added bonus of disabling auto-repeat and or debounce... does anybody know if the same can be used to GOSUB?
    or know of a solution to do the same?
    Since I have loops within loops the button presses keep being registered, but I cannot use the BUTTON function to GOTO since it will reset the count on the main loop
    MAIN:
      FOR CNT2 = 1 TO CNT
      IF PORTA.3 = 1 THEN GOSUB SHIP
      IF PORTA.0 = 1 THEN GOSUB FIRE
      IF CNT2 == CNT THEN GOSUB ADD
      GOSUB LCDUPDATE
      PAUSE 5
      NEXT
      GOTO MAIN
    As you can see I am using GOSUB as to not interrupt the "for..next" loop doing the count, but I need a way of stopping auto repeat on the button checks... (without pausing since this messes up the count timing) unless there is another way to have a definitive count?
    (watchdog timer perhaps? never used it)
    Basically so that when the user presses the button it will only increment by 1 and not auto repeat (due to the instructions per second) and increment by about 70 per press
    Any help will be greatly appreciated!
    Aug 2010
    Maryland, USA
    To make the button gosub instead of goto to, 1 solution is :
    main
     button goto no_ship 'if button is NOT pressed, skip the gosub
     gosub ship   ' if button was pressed gosub and return
    no_ship
     button goto no_fire
     gosub fire
    no_fire
    As for the multi press and the way you are doing it, you have to check for when the button is released also. So when you have a button press, set a flag, then next time through the loop, if the flag is set, ignore the press. when the button is released, clear the flag.
    If cnt2==cnt gosub add
    you can move this line outside of the for next loop. It will be true each time the loop counts to cnt. so just process it before jumping back to main.
    as for the counting, you could use a timer setup as a counter. Just load it with a number, then in your mainloop check for an overflow. If it did, call your add. This way, as the levels get harder, just change the preload for the timer.
    -Bert
    Sep 2010
    ahhh yes of course... *facepalms*
    I will go about adding a flag in there now, seems I had a bit of a well I dunno what to call it actually lol
    That will solve the final few problems and a first draft version will be ready =)
    I havnt added the "n" bit yet or proper scoring system (it just counts the ammount you shot) but it does have lives, levels, shooting anywhere, etc etc etc...
    just a matter of time
    Sep 2010
    Default Version 1
    Forgot about this thread,
    First version is complete and has basic scoring with increasing difficulty and levels, will be adding proper scoring, motherships (n) and sound when I can get the bits.
