How to calc max debug rate?
Results 1 to 10 of 10
    Dec 2008
    Los Angeles, CA
    Default How to calc max debug rate?
    I'd like to know how to determine the maximum DEBUG baudrate using a PIC18F2420 running on an INTERNAL 8 MHz oscillator? Can someone help me out here?
    You can run debug at 38400 using 8 mhz, but I don't know the calculation.
    Walter
    http://www.scalerobotics.com
    Dec 2008
    Los Angeles, CA
    I was hoping for 57600, but knew it would be close. I never know until I try, but can't do that until tomorrow. I just dont have the space on this board for an external xtal/osc.
    May 2007
    Turn on the PLL to get a 32MHz clock?
    Dec 2008
    Los Angeles, CA
    I've been reading that the clock frequency is not as stable and may need to be tuned over time. In this application, it's going to be pretty inaccessable and I need to be able to trust that the serial port will work reliably over time, so I've pretty much decided against the PLL.
    You are using the internal already, so PLLing will not change that.
