Help with CRC checksums
Results 1 to 5 of 5
    This should do it for you.
    http://www.picbasic.co.uk/forum/show...8599#post78599
    Just zero the CRC variable first, then feed the subroutine 1 byte at a time.
    Your data is "8e f6 a2 b4 3a 6f 00 01" in hex, and the CRC result is $C344.
    I've tested it here, and it matches your CRC.
    FYI: It is a CRC (Cyclic Redundancy Check). A Checksum is something entirely different.
    Nov 2006
    Default Thanks Darrel
    Thank you Darrel. I still cannot figure out the CRC process, but I had no trouble getting your subroutine to work. So I am just going to purloin what you have written and stop thinking about it for now. On to more pressing issues (like getting the PIC to read in the data--not as easy as I thought it would be).
    Cheers,
    E
