Shift Function gives MPASM error
Results 1 to 7 of 7
    It would help if you would show your whole code.
    What is the value of B1?
    Sep 2010
    The value of B1 does not seem to affect the error message. I have tried forcing B1 to 1, 40 and 255 and the error message is the same.
    This compiles fine here
    B1  var BYTE
    B1 = 255
    B1 = B1 << 5
    So the problem is someplace else.
    Sep 2010
    I have just found that if I comment out the following include files, the shift function in the main program compiles/assembles without error.
    With the shift function omitted and these files included, the program compiles/assembles without error and runs perfectly so somehow one of them is affecting MPASM and shift functions.
    'INCLUDE "DT_INTS-18.bas"
    'INCLUDE "ReEnterPBP-18.bas"
    'INCLUDE "NewRXbuff.inc"
    What is
    The other two if unchanged are good files.
    Sep 2010
    Problem is fixed.
    My original include files looked like:
    INCLUDE "vars4.inc"
    GoTo Initialise
    INCLUDE "ReEnterPBP-18.bas"     ; Include if using PBP interrupts
    INCLUDE "Init18_4.inc"
    INCLUDE "Rxmsg18_1.inc"
    INCLUDE "Scan2.inc"
    INCLUDE "Display4.inc"
    INCLUDE "Process18_4.inc"
    INCLUDE "MonMode_1.inc"
    INCLUDE "MSSP.inc"
    Whilst the Goto immediately after "vars..." may look strange, it was done this way many years ago when the project used a PIC16F876. I can't remember the reason for doing it this way but it always worked when assembling with PBP so there has been no reason till now to change.
    With this new version of the project using a PIC18, by removing or moving the Goto the project now compiles/assembles without error. My includes are now:
    INCLUDE "vars4.inc"
    INCLUDE "Scan2.inc"
    INCLUDE "MSSP.inc"
    It still puzzles me why the PIC18 project worked perfectly until I added shift functions which then caused MPASM to generate errors.
    mackrackit, thanks for trying to help.
