Maths again...
Results 1 to 3 of 3
Thread: Maths again...
    Default Maths again...
    Hi.
    Can the DIV32 be used with constants? I have to make the division myvar=217770/adval and was thinking in using this:
    con1 con 21777
    con2 con 10
    dummy var word
    dummy=con1*con2
    myvar=div32 adval
    Is this OK?
    DIV32 can use a constant.
    But in your multiplication prior to the DIV32, one of the values have to be a WORD.
    Otherwise the constants are multiplied at compile time and the PBP system registers aren't loaded with the proper values at Run-Time.
    You can also use the PutMulResult macro I posted back in 2003.
    http://www.picbasic.co.uk/forum/show...24&p=50#post50
    Ooops. What a stupid idea to mult. 2 constants!
    Thanks Darrel.
