Using the TMP100 series of I2C temperature sensor from Texas Instruments
Results 1 to 4 of 4
    Nice one Aberco.
    Promoted to article here: http://www.picbasic.co.uk/forum/cont...as-Instruments
    http://www.scalerobotics.com
    Dec 2007
    Paris
    Bug report on the conversion routine... should be:
    TempL = TempL + 16 'adding 1 temperature unit
    Wiki article was fixed
    TempDec = 0
    IF TempL.7 = 1 THEN TempDec = 5000
    IF TempL.6 = 1 THEN TempDec = TempDec + 2500
    IF TempL.5 = 1 THEN TempDec = TempDec + 1250
    IF TempL.4 = 1 THEN TempDec = TempDec + 625
    can also be replaced by:
    TempDec = TempL * 625
    Not sure what takes the longest to compute, use whichever you like.
    Dec 2007
    Paris
    And more code cleaning... I don't need yet the part to display to LCD so that's why I haven't paid much attention to it. Works the same way but with much less resources.
    TempSign VAR Byte
    TempDec VAR Word
    'Convert temperature to LCD
    ConvertTemp:
    IF TempH.7 = 1 THEN
            TempSign = "-"
            TempL = TempL ^ %11110000 'bitwise invert on the 4 MSB
            TempH = TempH ^ %11111111 'bitwise invert
            IF TempL = 0 THEN
                    TempH  = TempH + 1
            TempSign = "+"
    LCDOUT $FE,1, TempSign, #TempH, ".", #TempL, "°C"
