ADC in 12F683; puzzled
Results 1 to 14 of 14
    Aug 2010
    Your program With the Config Header ... as always !!!
    Right, of cource...
    'Define ADCIN parameters
    ANSEL = %00000011 'GP0 = AN0, GP1 = AN1
    DEFINE ADC_BITS 10 'Set number of bits in result
    DEFINE ADC_CLOCK 3 'Set clock source
    DEFINE ADC_SAMPLEUS 50 'Set sampling time in us
    time1 VAR WORD 'First time in seconds
    time2 VAR WORD 'Second time in seconds
    time3 VAR WORD 'Third time in seconds
    involt1 VAR word 'Value for ADC0 (temp)
    involt2 VAR word 'Value for ADC1 (adjust)
    ut4 var bit 'Status for LED 4
    ut5 var bit 'Status for LED 5
    trip1 var word
    trip1 = 13300 'Default value
    trip2 var word
    trip2 = 13300 'Default value
    TRISIO = %11001011 'Defining PORT
    GPIO = %00111000 'Turn off all LEDs
    time1 = 0 'Zero time 1
    time2 = 0 'Zero time 2
    time3 = 0 'Zero time 3
    ut4 = 1 'LED 4 = off (inversed)
    ut5 = 1 'LED 5 = off (inversed)
    loop1:
    ADCIN 0, involt1 'Read channel 0 to involt1
    ADCIN 1, involt2 'Read channel 0 to involt2
    pause 100 'Wait 100 ms
    IF involt1 >= trip1 THEN
    GPIO.4 = 0 'Turn on LED4
    GPIO.4 = 1 'Turn off LED4
    IF involt2 >= trip2 THEN
    GPIO.5 = 0 'Turn on LED5
    GPIO.5 = 1 'Turn off LED5
    goto loop1 'Go back to loop1
    trip1 = 13300 gives exactly 1V trip level. I don't mind having this kind of resolution, but it doesn't seem realistic.
    Quote Originally Posted by mikebike View Post
    Right, of cource...
    Missing :
    - Deactivate comparators
    - ADC result right justified
    Aug 2010
    Thumbs up
    Missing :
    Is this specific for 10 bit ADC, or should it be there for 8 bit conversion as well?
    And how? -CMON0 something?
    Missing :
    Hm, the example programs that I have (for 16F877A) do not have such an instruction, does that PIC not need it?
    ADCON0.7 = 1 seems to have have cured the problem, thanks guys.
    have a look to datasheet ... Comparator section !!!
    some pins share the comparator and ADC functions ... you HAVE to verify which function is deactivated and which is to activate. ( one at a time ... )
    Depends on the chip used - and the ports used ...
    Full config done = NO suprise ...
    sometimes, the pic defaults @ reset are the ones you want ... sometimes not. so you have to verify everything with the pic Datasheet !!!
    Aug 2010
    Done that, but didn't understand it (new to this stuff).
    CMCON0 = %00000000
    seems to be accepted by PBP and the chip (still) works.
    CMCON0 = %00000000
    Boooooooooooooo .... the chip is really gentle with you ...
    look a bit closer at the drawings and the corresponding config @ $8 p 53 ...
    Aug 2010
    I said that I don't understand this kind of data sheet...
    Well, I think it says that .....000 only turnes the comp output off, but ....111 turnes the comp off as well. It doesn't matter much for this project, but my first project is battery operated and saving some current is welcome.
    I guess it's nice to have a comparator integrated, but right now I would need an OP-amp instead!
    Aug 2010
    Yes, I have had some interesting output signals on outputs that were not specified in the program!
