code conversion
Results 1 to 4 of 4
Thread: code conversion
    Oct 2008
    Default code conversion
    Hi All
    i have a checksum calculation routine that works in Visual Basic i am trying to convert to PicBasic.
    the source for the checksum are the first 32 locations in a AT93C46 EEprom (16 bit mode).
    i am sure i am doing something stupid but all i get with the Picversion is FFFF,FFFF(sometimes FFFF,7FFF) independent of the eeprom contents.
    after spending 5 days on this i hope some fresh eyes will spot my error.
    thanks in advance
    dj.lambert
    VB code:
    <code>
    Private Sub Checksumme(dat$)
    ' Checksumme berechnen
    Dim x, d, cs$
    adrx1 = 1: adrx2 = 31: GoSub summe1x
    cs$ = Right$("00" + Hex$(summe), 2)
    adrx1 = 9: adrx2 = 18: GoSub summe1x
    cs$ = Right$("00" + Hex$(summe), 2) + cs$
    'Stop
    cs = cs$
    Label5.Caption = "Checksum : " & cs
    If writecsum = True Then
    WriteCheckSum cs$
    'Stop
    End If
    writecsum = False
    Exit Sub
    summe1x:
    summe = &HA5
    For x = adrx1 To adrx2 Step 1
    d = Mid$(dat$, x * 5 + 1, 4)
    'Stop
    d = Val("&H" + Mid$(dat$, x * 5 + 1, 4))
    summe = (summe + (d And &HFF)) And &HFF
    If (summe And 1) = 1 Then
    summe = summe \ 2 + &H80
    Else
    summe = summe \ 2
    End If
    summe = (summe + (d And &HFF00) \ &H100) And &HFF
    Else
    summe = summe \ 2
    End If
    Next
    summe = summe And &HFF
    End Sub
    </code>
    PicBasic code:
    <code>
    CheckSum:
    adrx1 = 1
    adrx2 = 31
    gosub summe1x
    adrx1 = 9
    adrx2 = 18
    gosub summe1x
    Summe1X:
    summe = $A5
    for addr = adrx1 to adrx2 step 1
    d= b3a(addr)
    temp=d
    serout2 PortB.1, 84, [hex summe, hex d, 10,13]
    summe = (summe + (templo)) and $FF
    serout2 PortB.1, 84, [hex summe, 10, 13]
    if (summe and 1) = 1 then
    summe = summe / 2 + $80
    summe = summe / 2
    summe = (summe + (temphi) / $100) and $FF
    summe = summe / 2
    next
    summe = summe and $FF
    </code>
    variable declarations for PB:
    B3A var word(32)
    temp var word
    tempLo var temp.byte0
    tempHi var temp.byte1
    adrx1 var byte
    adrx2 var byte
    CheckSumme var word
    Summe var word
    d var word
    Bombay, India
    Some observations
    1 - the VB code is reading 4 hex characters from locations (x*5 + 1) at a time. This is assuming VB is set to "option base 1"
    so, for index 1 it reads from 6, for index 2 it reads from 11 etc
    Your PB code is not doing that
    2 - the VB code is expecting HEX characters and converts them to a value using the val("&H" ......) operation.
    Your PB code is treating the values in the EEPROM as proper word values which they are not
    Oct 2008
    Hi Jerson
    thanks for the reply
    the 1st point i have removed the lines for that and forgot to put them back in (i removed them to make it a bit simpler to follow).
    the second point is i think where the problem with the conversion is occurring.
    i get compile errors if i try to force the variables to hex.
    dj.lambert
    Bombay, India
    Hi Dj
    You do not need to force the values to Hex, instead you need to convert the HEX values to word. Since PBP does not support a function like VB does, you need to build this code. A simple routine to convert a hex character to byte would be
    ' expects a HEX character with capitalized A-F values
    Hex2Bin:
        Hexchar = Hexchar - "0"          ' remove the value of ascii 0 (30H)
        if Hexchar > 9 then  Hexchar = Hexchar - 7   ' convert A-F to 0a-0Fh
    Now, you would do this 4 times once for each nibble in the word you are converting and get your Hex word like this
       WordVal = 0                              ' start with a val of 0
       read a hex character to HexChar
      gosub Hex2Bin
      WordVal = WordVal * 16 + HexChar
      gosub Hex2Bin
      gosub Hex2Bin
      gosub Hex2Bin
    Now, WordVal would contain the 16 bit representation of the 4 character Hex String
