Error message from Microcode Studio
Results 1 to 6 of 6
    Aug 2005
    Houston, TX
    Default More
    Quote Originally Posted by AMay View Post
    I use PICBasic, (not Pro.)
    When I try to compile using Microcode Studio, I get "out of memory, PBC.EXE."
    I am using Windows 7, and have compressed most of my hard drive, but not the PBC folder.
    I just moved from Vista, where all I had no trouble, but my HD was not compressed.
    I'll be grateful for help.
    Now, after removing "raed only" tags i get the error messsage "can't create run.bat"
    I am still out of business. (I have reinstalled all related programs of course.0
    If your Windows7 is 64-bit, then PBC won't run because PM.exe is a 16-bit program.
    If you have Win7-32, then be sure to right-click the install programs and "Run as Administrator".
    Aug 2005
    Houston, TX
    Thanks. I finally got it to work by moving my programs as a sub folder to PBC, and offering to share PBC and its sub folders with the universe. It did ask abiut running as administrator, and I said yes.
    I was afraid I was out of bsiness for a while.
