Indexing port pins for serout2/serin2
Results 1 to 10 of 10
    I was hoping there was an easy answer to this and someone would post, "You silly you have to do it this way...." or "Yes that code should work by you forgot about some setting in the programer." Hrm, I guess I'll go back to hacking away at the keyboard on Monday.
    You can use pin "Numbers".
    But the pins will need to be grouped within 2 full ports, instead of scattered like you've shown.
    Preferably PORTB and PORTC.
    0-7 is PORTB, 8-15 is PORTC, but they can be changed in the 16F877.bas file.
    for i = 0 to 15
        serout2 i, 8276, ["hello, this is PIN# ",DEC i]
        PAUSE 300
    next i
    Using the pin "number" was the first thing I tried because I saw them do it in the PBP manual. But when I implemented it I couldn't make any sense of how the "numbers corresponded to the actual ABCDE Ports. And for some 2 different "numbers" I can't remember which ones, would correspond to data coming out on the same pin.
    Why is PORTB.O = "number" 0 ? Where is PORTA?
    This is what is in my .bas file:
    '* 16F877.BAS *
    '* By : Leonard Zerman, Jeff Schmoyer *
    '* Notice : Copyright (c) 1998 microEngineering Labs, Inc. *
    '* All Rights Reserved *
    '* Date : 10/23/98 *
    '* Version : 2.11 *
    '* Notes : *
    BANK0 $0020, $007F
    BANK1 $00A0, $00EF
    BANK2 $0110, $016F
    BANK3 $0190, $01EF
    EEPROM $2100, $21FF
    LIBRARY "PBPPIC14"
    DEFINE CODE_SIZE 8
    include "PIC14EXT.BAS"
    PORTL VAR PORTB
    PORTH VAR PORTC
    TRISL VAR TRISB
    TRISH VAR TRISC
    include "PBPPIC14.RAM"
    '*-----------------------* EOF 16F877.BAS *---------------------*
    here is my .inc:
    ;* 16F877.INC *
    ;* By : Leonard Zerman, Jeff Schmoyer *
    ;* Notice : Copyright (c) 2003 microEngineering Labs, Inc. *
    ;* All Rights Reserved *
    ;* Date : 11/07/03 *
    ;* Version : 2.45 *
    ;* Notes : *
    NOLIST
    ifdef PM_USED
    LIST
    include 'M16F87x.INC' ; PM header
    device pic16F877, xt_osc, wdt_on, pwrt_on, lvp_off, protect_off
    XALL
    NOLIST
    LIST
    LIST p = 16F877, r = dec, w = -302
    INCLUDE "P16F877.INC" ; MPASM Header
    __config _XT_OSC & _WDT_ON & _PWRTE_ON & _LVP_OFF & _CP_OFF
    NOLIST
    LIST
    Thanks for the reply!
    Can I add ports A D and E somehow to the BAS file? I screwed aroud with trying to change the ports during runtime, but that doesn't seem to work.
    for i = 0 to 15
    PAUSE 300
    next i
    i = 0
    PORTL = A
    PORTH = D
    TRISL = A
    TRISH = D
    for i = 0 to 15
    serout2 i, 8276, ["hello, this is PIN# ",DEC i + 16]
    PAUSE 300
    next i
    next i
