Hi all
got that sensor for a while an I taught it would be nice to plug and play with it, but it's not behaving nice to me so far.
After a long read of the spec sheet, I came up with the following code
taugh it was pretty slick, but It does not work at allCode:'I2C data communication with HP01D, low cost pressure/temp sensor ;i2Dpin var PORTB.7 ;i2CLKpin var PORTB.6 ; HP01Pres var WORD ; HP01Temp var WORD ; ******* READING PRESSURE ************************************************* I2CWRITE i2Dpin,i2CLKpin,$EE,$FF,[$F0] ; resquest pressure reading from sensor ; $EE is WRITE command to the HP01D ; $FF is address to write in ; $F0 is to read Pressure , $E8 is to read temp pause 38 ; at least 38ms is required before we can read the data I2CWRITE i2Dpin,i2CLKpin,$EE,$FD ; set sensor for retrieve result ; $EE is WRITE command to the HP01D ; $FD set sensor to read? , I2CREAD i2Dpin,i2CLKpin,$EF,[HP01Pres.highbyte,HP01Pres.lowbyte],NoREADAck ; Read values ; $EF is READ command to the HP01D
I think there might be a problem at line
because i'm not sending any data? But that's the way the sensor wants it...
can shiftout do a trick here?
I also tried with I2C_SLOW setting, but no data comes out
