will not compile
Results 1 to 4 of 4
    Aug 2009
    Paso Robles California
    Default will not compile
    why do these two line have trouble compiling
    111 SERIN2 PORTA.2,16468,[HEX2 MONTH,HEX2 DATE,HEX2 YEAR,HEX2 HOUR,HEX2 MINUTES,HEX2 SECONDS]
    153 I2CREAD SDA,SCL,$A0,ADR,[HOUR,MINUTES,DATE,MONTH]
    C:\0 FILES\2MPLAB\TRACKER.BAS ERROR Line 111: Expected '['.
    C:\0 FILES\2MPLAB\TRACKER.BAS ERROR Line 111: Expected ']'.
    C:\0 FILES\2MPLAB\TRACKER.BAS ERROR Line 153: Expected '['.
    C:\0 FILES\2MPLAB\TRACKER.BAS ERROR Line 153: Expected ']'.Halting build on first failure as requested.
    BUILD FAILED: Mon Sep 20 10:00:01 2010
    They both compiles here but gave the same error before I had all the variables properly declared:
    Here, I've commented out the declaration of MINUTES and SCL and it gives pretty much the same error as you get. When I uncomment those declarations it compiles just fine.
    So, double check your variable declarations.
    If you want answers and not guesse, then it is good practice to post all your code, chip, IDE used.
    I can only guess now you may declared wrong chip, or you have something missing in you code listing.
    Aug 2009
    Your correct I was rewriting some old code for 1302 to 1307 and deleted my variables geez
