floting point variables?????
Results 1 to 3 of 3
    The aint variable is WORD sized. To get a larger number back from FP routines. Divide the result by 65536 to get the High Word. This is done before converting to an integer.
    HTH,
       Darrel
    I should probably mention that if you're using the 24bit FP routines, then it's really only 16bit with an 8bit mantisa. To do what you had originally stated in the other thread, you should be using the 32bit version of the FP routines.
    Darrel
  1. Max Variables
    By shawn in forum mel PIC BASIC Pro
    Last Post: - 19th January 2008, 05:05
  2. Floating Point Display Problem (serial string out)
    By Cash Olsen in forum mel PIC BASIC Pro
    Last Post: - 20th December 2007, 03:03
  3. Variables not appearing in Watch Window MPLabv7.3
    Last Post: - 16th June 2006, 15:36
  4. How to tell which PICs can handle 16 bit variables?
    By MikeTamu in forum mel PIC BASIC Pro
    Last Post: - 31st August 2005, 09:44
  5. Problems with variables
    By egberttheone in forum mel PIC BASIC Pro
    Last Post: - 15th December 2004, 19:37
