Pin as variable?
Results 1 to 11 of 11
    Jul 2010
    Cool Pin as variable?
    Is there a way to set a Pin as a variable?
    Something like:
    myPin = PORTB.1
    High myPin
    Pause 1000
    Low myPin
    myPin = PORTA.0
    High myPin
    Pause 500
    Low myPin
    Using myPin VAR PORTB.1 is not good since I cannot define the variable several times. Am I missing something obvious?
    Aug 2008
    Portugal
    Hi;
    Yes;
    like this;
    LED   VAR PORTA.1
    High led
    low led
    Thanks and Regards;
    Gadelhas
    Jul 2010
    Quote Originally Posted by gadelhas View Post
    Hi;
    Yes;
    like this;
    LED   VAR PORTA.1
    High led
    low led
    Thank you for your response, but as I mention in my original post, that is not what I am looking for, since you cannot define the variable repeatedly in the program. If you look at my example I am assigning two different Pins to the same variable. Thank you anyway
    Why do you want to use the same variable name for two different things?
    Jul 2010
    I am not using the same variable for two different things.
    I have a subroutine that sends a special signal through a pin, and I need to be able to control which PIN the signal is sent through.
    So the easiest way would be to do something like:
    myPin = PORTB.1
    gosub SendSignal
    myPin = PORTA.1
    Gosub SendSignal
    myPin = PORTA.0
    Gosub SendSignal
    SendSignal:
    HIGH myPin
    (Do more stuff)
    LOW myPin
    Pause T
    HIGH myPin
    T = something
    Pause T
    Low myPin
    (more stuff)
    High myPin
    Tf = T*something
    Pause Tf
    Low myPin
    Since the SendSignal routine is quite complex, I would like to implement it this way. I can't use a CASE SELECT either because everytime the routine has to do something with the pin, I would have to have a separate CASE block.
    Any ideas?
    myPin = PORTB.1
    Read the state of the pin and stores the value to myPin.
    HIGH myPin
    Is for making a pin HIGH.
    So the way you want to do it will not work.
    The only way I see to do what you want is to use an IF/THEN/ELSE block with three condiitons or CASE SELECT with three conditions.
