Pin as variable?
Results 1 to 11 of 11
    Jul 2010
    Why do you want to use the same variable name for two different things?
    I am not using the same variable for two different things.
    I have a subroutine that sends a special signal through a pin, and I need to be able to control which PIN the signal is sent through.
    So the easiest way would be to do something like:
    myPin = PORTB.1
    gosub SendSignal
    myPin = PORTA.1
    Gosub SendSignal
    myPin = PORTA.0
    Gosub SendSignal
    SendSignal:
    HIGH myPin
    (Do more stuff)
    LOW myPin
    Pause T
    HIGH myPin
    T = something
    Pause T
    Low myPin
    (more stuff)
    High myPin
    Tf = T*something
    Pause Tf
    Low myPin
    Since the SendSignal routine is quite complex, I would like to implement it this way. I can't use a CASE SELECT either because everytime the routine has to do something with the pin, I would have to have a separate CASE block.
    Any ideas?
    myPin = PORTB.1
    Read the state of the pin and stores the value to myPin.
    HIGH myPin
    Is for making a pin HIGH.
    So the way you want to do it will not work.
    The only way I see to do what you want is to use an IF/THEN/ELSE block with three condiitons or CASE SELECT with three conditions.
    Jul 2010
    PERFECT!
    This is exactly what I was looking for. Thank you Darrel.
    Jul 2010
    myPin = PORTB.1
    HIGH myPin
    Yes, I know it wont work, that's why I am asking if there is a way to do something like that.
    Right, that's what I said in my previous post. I want to avoid using CASE or IF/THEN blocks because of the number of times I have to invoke the PIN in the routine (In my actual code I don't have just 3 conditions). It is just not practical to have so much redundant code as I need the space for other things.
    Thank you anyway, I appreciate your taking the time to look at my problem
    Do not give up. Darrel came to the rescue again with the link he posted.
    Jul 2010
    Yes, and I already implemented it!. Works like a charm.
    Thank you guys again!
    (One happy camper glad he didn't have to recode everything in C)
