If...then...else
Results 1 to 10 of 10
    Aug 2010
    Default If...then...else
    Why do I get a Syntax Error for the ELSE row?
    loop2:
    ADCIN 0, involt 'Read channel 0 to involt
    PAUSE 100 'Wait 100 ms
    IF involt >= 128 THEN GPIO.5 = 0
    ELSE GPIO.5 = 1 ENDIF
    GOTO loop2
    PIC12F683 & PBP2.60
    ELSE likes to be on a line of it's own.
    Try
    loop2:
    GPIO.5 = 1
    GOTO loop2
    Aug 2010
    No, didn't help:
    ERROR Line 30: ELSE without a matching IF..THEN. (ADC1.pbp)
    ERROR Line 32: ENDIF without a matching IF..THEN. (ADC1.pbp)
    That would suggest that they should all be on the same row, but that was my first attempt.
    Wink
    Quote Originally Posted by mikebike View Post
    No, didn't help:
    loop2:
      GPIO.5 = 0
      GPIO.5 = 1
    GOTO loop2
    Aug 2010
    Thanks, that worked. But why?
    IF xxx THEN label
    can be on one line because it act as a GOTO.
    If not a label the THEN needs to be on a second line.
    YUP, I messed up on my first post. Was not paying attention...
    simply because the compiler considers there's no need for ELSE nor ENDIF, if he sees anything on the right side of THEN ...
