Generate a random number between 0 and X
Results 1 to 8 of 8
    Jun 2007
    Mansfield, UK
    Yes, Im using the low byte. That gives me 0-255 though. I have another variable that contains a value between 0 and 255 and i need the random number to be between 0 and that.
    May 2008
    Italy
    Something like this should work:
    Rnd0 var word
    Rnd1 var byte
    Lim var byte ' your limiting variable (0 - 255)
    Random Rnd0
    Rnd1 = Rnd0 */ lim
    Al.
    Jun 2007
    Mansfield, UK
    Ive not seen that operator before. What does it do? Ive had a look at the online manual and it says it "returns the middle 16 bits of the 32-bit result". Im not sure if thats what i want.
    I know i could get to the correct value using the following equation
    Rnd1 = (Rnd0.byte0 / 255) * lim
    That one wont work though because it will be rounded to 0 or 1 when dividing.
    May 2008
    Italy
    Tray to multiply first.
    Rnd1 = (Rnd0.byte0 * lim)/ 255 [which is the same as Rnd1 = (Rnd0 */ lim)]
    Al.
    Jun 2007
    Mansfield, UK
    Ahh, I think i understand how */ is working now. Ive tried both ways and they seem to be working for a few seconds then my LED freezes but i think thats to do with something else. Thanks for your help
    Jun 2007
    Mansfield, UK
    Ive figured why the LED freezes now. After generating the random number i was using */ and storing the result back in the same variable. It looks like the RANDOM command uses whats already in the variable as a seed and as i was modifying the value to really low numbers, eventually it was hitting 0 and staying there. I added a second variable and its all working now
