Generate a random number between 0 and X
Results 1 to 8 of 8
    Jun 2007
    Mansfield, UK
    Default Generate a random number between 0 and X
    Hi, I already know i can use the RANDOM command to generate a 16 bit random number. The problem is that i dont know how to generate one that is between 0 and anything upto 255. The upper value is specified by another variable. Ive seen a few examples including one from this site that uses ** but i cant seem to get any of them to work correctly.
    Im working mainly in assembly but i dont mind examples in PBP.
    May 2008
    Italy
    You can use only the low byte or the high byte of the randomized word.
    Al.
    Jun 2007
    Mansfield, UK
    Yes, Im using the low byte. That gives me 0-255 though. I have another variable that contains a value between 0 and 255 and i need the random number to be between 0 and that.
    May 2008
    Italy
    Something like this should work:
    Rnd0 var word
    Rnd1 var byte
    Lim var byte ' your limiting variable (0 - 255)
    Random Rnd0
    Rnd1 = Rnd0 */ lim
    Al.
    Jun 2007
    Mansfield, UK
    Ive not seen that operator before. What does it do? Ive had a look at the online manual and it says it "returns the middle 16 bits of the 32-bit result". Im not sure if thats what i want.
    I know i could get to the correct value using the following equation
    Rnd1 = (Rnd0.byte0 / 255) * lim
    That one wont work though because it will be rounded to 0 or 1 when dividing.
    May 2008
    Italy
    Tray to multiply first.
    Rnd1 = (Rnd0.byte0 * lim)/ 255 [which is the same as Rnd1 = (Rnd0 */ lim)]
    Al.
