String to number conversion
Results 1 to 5 of 5
    Sep 2009
    You may be able to look at this and work it out in PBP
    It's from sowrdfish basic
    Public Function StrToDec(pValue As String) As LongWord
       Dim Value As Byte
       Dim IsSigned As Boolean
       FTextAddress = @pValue
       Result = 0
       Value = FTextIn
       IsSigned = false
       If Value = Byte("-") Then
          IsSigned = true
          Value = FTextIn
       EndIf
       While Value <> 0
          Result = 10 * Result + (Value - 48)
          Value = FTextIn
       Wend
       If IsSigned Then
          Result = Not Result
          Inc(Result)
       EndIf
    End Function
    Bombay, India
    PBP does not support floats. So, converting those numbers will be difficult.
    However, if like a challenge, this is a rough draft of how I would try my hand at it. This is not the best code that can be written for this though; just a pointer.
    IntResult = 0
    FractionResult = 0
    Exponent = 0
    Units = ""
    WhichPart = 0                   ' 0 = Integer part, 1 = fractional part, 2 = exponent part
    ExpFlag = 0                       ' set to 1 when reading the exponent
    Pointer = points to start of number
    while (character@Pointer != end of string)
        select case WhichPart
        case IntPart:              ' whichpart = 0
            IntResult = IntResult * 10
            select case character@pointer
            case "0" to "9":
                   IntResult = IntResult + (character@pointer-'0')
            case "."
                   WhichPart = 1         ' now on, gather fractional part
            end select
        case FractionalPart:      ' whichpart = 1
            FractionResult = FractionResult * 10
            case "0" to "9":
                   FractionResult = FractionResult + (character@pointer-'0')
            case "e" OR "E":
                   WhichPart = 2         ' now on, gather Exponent
            end select
        case ExponentPart:              ' whichpart = 2
            Exponent = Exponent*10
            case "0" to "9":
                   Exponent = Exponent + (character@pointer-'0')
            case else
                   Units = character@pointer
            end select
        end select
        ' move to the next character
        increment Pointer by 1
    wend
    This is purely 'pseudo code' and not PBP though it looks a bit alike. At the end of this routine, you should have 4 values - Integer result, Fractional Result, Exponent and Units either V or A. Now, you combine them as you deem fit and have your resulting answer
    Jul 2010
    Try this works great for me. Handles string to float conversions and can be connected to other microcontrollers. Also supports Picbasic Pro with examples.
    http://www.micromegacorp.com/umfpu-v3.html
    Bryan
    Oct 2008
    thanks for all the ideas.
