XBee Mesh networking
Results 1 to 11 of 11
    Miami, Florida USA
    Quote Originally Posted by NL2TTL View Post
    I Like to hear good / bad experience from this forum users.
    Well, I hope I'm wrong but I haven't seen much information about XBee modules and PBP either. I'm also trying to make some XBee modules work. I'm using the MRF24J40MA modules. I've been forced to use C, since I haven't found much information in PBP. There are plenty of Wireless Networking Protocol Stacks and sample programs out there in the web but all of them are in C language.
    Anonymous
    Hi NL2TTL.
    Which XBee are you planning to use?
    Sorry for the late reply but i want to use the XBEE-Pro modules
    I suppose Zigbee modules, right?
    Well, you do not have to do alot, jut connect them and you have established a network. Data-in, Data-out.
    You just have to make one module co-ordinator. If you buy the Dev-kit things are much simpler for the set up.
    sinoteq's Avatar
    sinoteq Guest
    You can also use the CC2500 chip from TI. Not Zigbee but if you only need to send data inside your own developed network it should work. Of course a bit difficult to get started with but worth it.
    I'm Using the XBEE modules from DIGI.
    When I set one module as co-ordinato, I have to use the API for communication. Only then its possible to use sending and receive addresses. (correct me if i'm wrong).
    Data IN / Out is already done.
    Setting a co-ordinator does not have to do with API.
    You have to use API for special data handling, remote configuration or other specia functions.
    OK, maybe I did not understood what you are up to.
    Please detail what are you trying to do exactly.
