16f88 setting config
Results 1 to 7 of 7
    Sep 2009
    Default 16f88 setting config
    Just two little ones
    How do you set the config right for the 16f88
    This is what I would start with if I was using asm
         __CONFIG    _CONFIG1, _CP_OFF & _CCP1_RB0 & _DEBUG_OFF & _WRT_PROTECT_OFF & _CPD_OFF & _LVP_OFF & _BODEN_OFF & _MCLR_ON & _PWRTE_ON & _WDT_OFF & _INTRC_IO
         __CONFIG    _CONFIG2, _IESO_OFF & _FCMEN_OFF
    If I want to list my chip DEVICE PIC16F88
         LIST      p=16F88              ; list directive to define processor
         #INCLUDE <P16F88.INC>          ; processor specific variable definitions
    Why doesn't show the INC in the left pane of microcode studio that nice to have there
    you could pop it up and find what registers you need to set
    Put this in your code if you have commented the *.inc.
    @ __config _CONFIG1, _INTRC_IO & _WDT_OFF & _LVP_OFF & _MCLR_OFF &_CP_OFF
    Your second question makes me think you are confusing PBP with something else.
    Sep 2009
    Thanks I 'll try that right now
    Dec 2012
    Default Re: 16f88 setting config
    I am getting the head out th neck!
    I got that Willem Universal burner as the picture here, I am trying to program a 16f88 microchip with some hex code I got to make a frequency multiplyer\ divider .....
    It is Willem 5.0c Burner Circuit Version
    I am using "Ic-Prog" as it is free and is compatible with 16f88
    I tried everything, but it does not write nothing to the pic micro-controller!
    Can some one help me to sort out this? how to test the voltages that must come to that? also ...how what is this error "0000h" error verifying????
    I installed confused the "totalio", but .... it keeps giving the error message!
    Can some one help me to check if it is jumped properly the burner and what is happening?
    IC-Prog may be compatible with the 16F88. The Willem programmer may be compatible with the 16F88. But is the IC-Prog software compatible with the Willem programmer?
    I'm not saying it is or isn't, just raising a point.
    Didn't the Willem programmer come with its own software?
    Dec 2012
    16f88_problems.pdf
    please, some one help me
    Dec 2012
    i will try to check and add components to make this hardware configuration in the own willem board pcb5.0c
