Copy 144 LED console for my school project
Results 1 to 39 of 39
    Does the $6,000 include a working prototype?
    I wish I could charge that amount of money for my consultancy too...
    May be I have to change country.
    Seriously now. Mtripoli has absolutely right on alsmost all the points. I do not like to the attitude of some members too.
    And would never agree on giving the food on the plate. So for these members the direction to find their food is my option.
    I know that these kind of posts for "give that", "do this for me", etc will never stop. People are trying to get the best for them with minimal labor. It is in our nature. Others do more work, others not.
    Ignore them who are not worth it and spend your time creatively instead of commending it about it. After all your time is precious and they will not read it!
    Talking Of course!
    No "working prototypes"; actual production ready modules.
    $6000.00 might sound like alot but it includes the obvious aggravation factor that would be involved here.
    Because of the proliferation of the DIY "modules" and DIY PCB etc. there is this idea that designing electronics is cheap. It's not. Slapping together a few parts and calling it done is not a design. I won't go into it because frankly it would be a waste of time. I design products designed for millions of units per run. If I did things the way I see some around here do I wouldn't be a design consultant, I'd ask people every day "you want fries with that".
    The REAL problem here is that any human being has this inherent want to help others. I do too. However, when people start a thread with "I know nothing about electronics or this stuff" and then continue on with nonsense it can get under your skin real fast. Or, in this case jump on a Picbasic forum and ask for C code; come on, get real.
    I think there is a very simple solution to this kind of problem. I've seen it suggested before in one form or another and the suggestor gets slammed for it. There should be a test to gain entry to the site. If you can't pass a simple test on basic electronics then you should go somewhere else. Immediately "beginners" say "but I came here for help". I'm talking about the truly basic; ohms law, transistor switching, simple logic, an "increment x" program. I in fact happened upon an electronics site that had just this kind of "entrance exam". It was for high-end audio amp design. I took the test and failed. I only failed by a couple of questions, but the fact of the matter is the people that were members of that site could converse with each other on a level that they all knew what the other was talking about. If I wanted to join it was on me to go learn what the things are that I failed. This site is open to anyone with a computer. I stopped coming here because you had to weed through all the nonsense to find the posts from people that had something genuine to offer or the ones that knew what they are doing but need help. Frankly, it's too bad it's called the "PICBASIC" forum. It sheds a bad light on a very good product and the people that are genuinely interested in using it.
