Copy 144 LED console for my school project
Results 1 to 39 of 39
    Sep 2010
    Default thank you^^
    You will find mention of it in a couple different posts. But you can check the schematic link at the bottom of post# 50 (under picture). Please read the posts. I think it will answer most of your questions.
    thank you thank you thank you thank you very much...for you concern to us...because right now we already started this project...
    You can also check out the Wiki file on this subject. I have updated the download file to include the newer pdf files.
    http://www.picbasic.co.uk/forum/cont...onsole-Project
    http://www.scalerobotics.com
    Aug 2003
    Wow, sorry, haven't checked the thread for a while.
    The EEPROM can be ignored.
    You can make the circuit as if it is there, and just omit it.
    The data for the message scroller is now read from the pics EEPROM,
    and is therefore limited to the EEPROM space in the 16F877.
    can you please send to me the program of 144LED message scroller only it is possible to remove the games in prgram and only the message program is thereor can used?
    You can make the circuit as it is, and leave out the buttons.
    Then the program will start with the message scroller every time.
    If you were asking because you wanted to actually remove game code to free program space
    for other stuff, well that should be easy too.
    The routines for games are clearly identified in the Picbasic source code provided.
    can you please send to me the program in C++ please....
    Pls refer to what scalerobotics said
    I was unemployed when I did this project, and now work full time with a lot of travel hours.
    Were I still unemployed, I might take this up as a challenge and complete it again in Microchip's C30 compiler.
    Art.
    Sep 2010
    Smile Thank you for your support^^
    Art.
    I Have some problems because the BC549C transistor is not available .. but i do not know if this transistor BC548B can be substitute?..
    I'm so glad to find this kind of project were our FINAL project for this semester and after we finish this project i will send to you the FINAL output of our work and SOMEDAY i want to meet you and say THANK YOU VERY MUCH^^
    more power to you and i hope many like me(student's) that you can help..^^
    Aug 2003
    Obviously you are the same person as on All About Circuits forum
    where the project is also posted.
    Short answer is YES.. BC548B is a NPN transistor.
    Some substitutes are:
    BC109C, BC149C, BC549 & 9014.
    Cheers,
    Art.
    Last edited by Acetronics2; - 5th September 2010 at 10:22. Reason: 107 ... 547,548,549 are ... NPN !!!
    Sep 2010
    Smile Thank you
    Cheers,
    Art.
    hehehe^^...
    THANK YOU very very much^^ now im satisfied...for this transistor^^ maybe for this coming days..i need to ask some question about in program but for now on we need to do this circuit first...anyway
    THANK YOU AGAIN..^^ GOD BLESS
    Sep 2010
    Smile C SOURCE..compiler...
    i have some problem in program..because...it is not work in PIC C compiler..may be because the program language is different..
    i want to ask if you can convert it into c source... please...help me again for this problem because at the end of the month we need to defense our project that's why im so nervous and also pressured,...
    but i know you are here..to help us...
    THANK YOU...and i hope...so much to you...^^
