http://www.scalerobotics.com
You can also check out the Wiki file on this subject. I have updated the download file to include the newer pdf files.
http://www.picbasic.co.uk/forum/cont...onsole-Project
Wow, sorry, haven't checked the thread for a while.
The EEPROM can be ignored.
You can make the circuit as if it is there, and just omit it.
The data for the message scroller is now read from the pics EEPROM,
and is therefore limited to the EEPROM space in the 16F877.
You can make the circuit as it is, and leave out the buttons.can you please send to me the program of 144LED message scroller only it is possible to remove the games in prgram and only the message program is thereor can used?
Then the program will start with the message scroller every time.
If you were asking because you wanted to actually remove game code to free program space
for other stuff, well that should be easy too.
The routines for games are clearly identified in the Picbasic source code provided.
Pls refer to what scalerobotics saidcan you please send to me the program in C++ please....
I was unemployed when I did this project, and now work full time with a lot of travel hours.
Were I still unemployed, I might take this up as a challenge and complete it again in Microchip's C30 compiler.
Art.
I Have some problems because the BC549C transistor is not available .. but i do not know if this transistor BC548B can be substitute?..
I'm so glad to find this kind of project were our FINAL project for this semester and after we finish this project i will send to you the FINAL output of our work and SOMEDAY i want to meet you and say THANK YOU VERY MUCH^^
more power to you and i hope many like me(student's) that you can help..^^
Obviously you are the same person as on All About Circuits forum
where the project is also posted.
Short answer is YES.. BC548B is a NPN transistor.
Some substitutes are:
BC109C, BC149C, BC549 & 9014.
Cheers,
Art.
Last edited by Acetronics2; - 5th September 2010 at 10:22. Reason: 107 ... 547,548,549 are ... NPN !!!
