Copy 144 LED console for my school project
Results 1 to 39 of 39
    Sep 2010
    Smile Substitute for 24LC512
    We have a problem for this kind of IC because it is not available from the market here in the Philippines that's why we need to know what are those IC that can be substitute or other IC that can be used in our project 144 LED message scroller..
    i hope you can help me...
    THANK YOU^^
    Quote Originally Posted by luckyb0y7 View Post
    THANK YOU^^
    If you read the thread, you will see that this IC has been removed in the current design.
    http://www.scalerobotics.com
    Sep 2010
    Default Thank you for your concern
    ^^ im sorry but can i ask some favor hmm...can you please send to me the link of that current design because we are already confused...
    You will find mention of it in a couple different posts. But you can check the schematic link at the bottom of post# 50 (under picture). Please read the posts. The posts in this thread will answer most of your questions. All you have to do is read a little.
    Sep 2010
    Default thank you^^
    You will find mention of it in a couple different posts. But you can check the schematic link at the bottom of post# 50 (under picture). Please read the posts. I think it will answer most of your questions.
    thank you thank you thank you thank you very much...for you concern to us...because right now we already started this project...
    You can also check out the Wiki file on this subject. I have updated the download file to include the newer pdf files.
    http://www.picbasic.co.uk/forum/cont...onsole-Project
    Aug 2003
    Wow, sorry, haven't checked the thread for a while.
    The EEPROM can be ignored.
    You can make the circuit as if it is there, and just omit it.
    The data for the message scroller is now read from the pics EEPROM,
    and is therefore limited to the EEPROM space in the 16F877.
    can you please send to me the program of 144LED message scroller only it is possible to remove the games in prgram and only the message program is thereor can used?
    You can make the circuit as it is, and leave out the buttons.
    Then the program will start with the message scroller every time.
    If you were asking because you wanted to actually remove game code to free program space
    for other stuff, well that should be easy too.
    The routines for games are clearly identified in the Picbasic source code provided.
    can you please send to me the program in C++ please....
    Pls refer to what scalerobotics said
    I was unemployed when I did this project, and now work full time with a lot of travel hours.
    Were I still unemployed, I might take this up as a challenge and complete it again in Microchip's C30 compiler.
    Art.
    Sep 2010
    thank you^^
