http://melabs.com/resources/samples/pbp/sdfs3.htm
It was a hidden link![]()
LOL - yeah right !!
Interesting and seems a simple project... the only thing is that I don't have 6 pins available, at least not without changing the package to a 44 pin package and even then I still think it would be tight or short of a pin.... not to mention the re-design of the PCB
Thanks for the link though...
I've opted to do the logging in the PC application, for now![]()
malc-c , Why on earth would you need 6 pins for external eeprom storage? I currently use 4, 24LC1025's to store data for a little over a month @ 1 minute intervals. The data is stored for approx. 750 minutes a day during daylight. The data stored is 16 bits per variable of: pointer,azminuth,elevation,up,down,east west and status words. The amount of data you are trying to store isn't much. besides, I only use 2 pins for the 4, 24lc1025's giving me a little over 4 Migabits...
Six pins for an SD card.
Your suggested data output string needs comma delimiters since you cannot be certain of the character length of each value. You could serout each word as Dec3 mYvAR to force them all to a known length but that can complicate the end use of the data. If you comma delimit each value, terminate the line with <cr><lf> and label the file as MyLog.csv then Excel can open the file and graphing the data is a breeze.
I use word variables for TemperatureLogged = 1000 + (10*MeasuredTemperature) and depending on actual temperatures the number can have two or three digits. By adding 1000 I can send negative values without needind a sign bit. e.g 890 means -1.1C and 1234 +23.4C
My data loggers record date & time, temperature, pressure, accelerometers for an activity indication and heart rate. I log the data to M25P128 serial memory chips.
HTH
BrianT
Brian, thanks for the input.
As Dave has already mentioned, the 6 pins were for the SSD card shown in his link.
I gather that using I2C type memory chips I could use the same CLK and DTA lines that hook up to the DS1307 RTC chip, and just give the memory chip a different address, so that would save me a couple of pins?
Given that all I really want to store is date, time, temp1, temp2, temp3, temp4 probably every two minutes what would be the ideal memory chip to get to hold a minimum of 7 days worth of data (if longer so much the better). I was also thinking of a rolling data process, so that when full it would simply delete the oldest data to make space for the most current set, ie so it retails the past 7 days (or what every it amount to) worth. Any suggestions of code to do this would be welcome.
