How many serial ports can 1 PIC handle?
Results 1 to 4 of 4
    Feb 2005
    Bellevue
    Question How many serial ports can 1 PIC handle?
    I am using a 16876A for prototyping. It reads in from the PC, and then reads out to an LCD, the PC, and I want it to read out to a GPS also..
    I have used ports as follows:
    Cpinin var PortC.7 ' for PC in
    Cpinout var PortC.6 ' for PC out 9600b - works
    Apinout var PortA.0 ' out to LCD serial 9600b - works
    AGPSout var PortA.1 ' out to GPS - serial 4800b - not working!
    PORTA = %00000 'Initialize PortA to all zeros - all output
    TRISA = %00000 'All port A output
    PORTB = %00000000 'Initialize PortB to all zeros
    TRISB = %00000000 'All port B output(not using B for serial)
    PORTC = %01000000 'Initialize PortC to all zero except 7
    TRISC = %01000000 'All port C pins are output except pin 7 which is input (RX)
    I can't seem to find a way to get any more than 2 ports to work.. Hooking up to PortA.1, 2,3,4,5 never seem to get any data out...
    Am using SEROUT2 - but get no data on this last port:
    serout AGPSout, 188,[,10,13,"$GPWPL,",#Dec_lat1,".", #Dec_lat2]
    Is it that the PIC only can do 2 serial ports?
    Tom
    never tested many serial outputs but what about if you disable the A/D converter on PORTA??
    ADCON1=7
    Feb 2005
    Bellevue
    Cool Figger'd it out...
    It was a dumb mistake -- as usual..
    I had configured the output via SEROUT2 driven true none - 84 like the one going through the RS232 chip.. this does not... Needed to be driven inverted none 16468.. fix that and presto.. not a problem...
    Sorry for taking up the bits on such a simple problem..
    TG
    Quote Originally Posted by Tom Gonser
    TG
    of course not the last to be done That's happen to everybody playing with those toys !!!
  1. My code for TV remote and MIBAM for RGB control
    By idtat in forum Code Examples
    Last Post: - 12th January 2013, 21:52
  2. one line led light make image
    By bioul in forum mel PIC BASIC Pro
    Last Post: - 13th February 2008, 13:19
  3. Serious Serial Situation Setbacks...
  4. DS1820 headache
    By Calco in forum mel PIC BASIC Pro
    Last Post: - 12th August 2004, 01:28
  5. New member
    By jmgelba in forum mel PIC BASIC Pro
    Last Post: - 28th February 2004, 23:44
