HSERIN HSEROUT - Baud rate help
Results 1 to 7 of 7
    New Zealand
    Thanks - it works a treat now! Really appreciate your help. That Mister E is a clever fello
    New Zealand
    Default Sorry guys I'm back
    The PIC16f722 was doing funny things, in desperation I threw it away and went back to the trusty 16F88 however this is not working for me either.
    The PicKit 3 I bought was driving me mad also, so it's back to the ETT programmer and PicKit 2 software.
    It compiles and assembles ok, but it will not program. The programmer says "Verification of Configuration Failed" It programs fine if I get rid of anything to do with HSEROUT the defines and the command.
    But the instant I bring in an HSEROUT command it will fail.
    Here's the code:
    @ __config _CONFIG1, _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLR_OFF
    'pic16f88
    ADCON0 = %00000000      'ADC Disabled
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    ANSEL = 0 			'ALL DIGITAL
    CMCON = 7 			'COMPARATORS OFF
    INTCON = 0 			'Disable interrupts
    TRISB = %00001111 		'SET PORTB RB2(RX) as input, others to OUTPUT
    TRISA = %00000000 		'SET PORTA AS OUTPUTS
    porta = 63
    PAUSE 1000
    'LeftBtn Var PORTB.1
    'RiteBtn Var PORTB.3
    'StopBtn VAR PORTB.0
    'RadioEn var PortB.4
    B0      VAR BYTE
    B1      var byte
    B2      var byte
    TXdata  var byte
    Direction var byte
    LEDPtrn var byte
    WakeVar var byte
    MtrPwr  var bit
    clear
    porta = 0
    start:
    txdata = 100
    hserout [txdata]
    goto start
    I'm going completely nuts over this and I think I'm about to get fired for being so useless. Please help
    I do not know what is going on with the HSEROUT but you may want to correct something else. Who knows, maybe it will solve the other.
    RA5 can only be an input. You have.
    Then this
    porta = 63 = 00111111
    malc-c's Avatar
    malc-c Guest
    On the 18 pin device it appears that RA7 is also input only !
    http://ww1.microchip.com/downloads/e...doc/30487c.pdf
    Also, and whilst no expert on your settings you have
    porta = 63
    PAUSE 1000
    you have set PORTB as output apart from RB2 but appear to have buttons which are normally inputs ( taking pin high or low) on RB1, RB3, RB0 and RB4 ?, but appear to have set it correctly with TRISB = %00001111
