HSERIN HSEROUT - Baud rate help
Results 1 to 7 of 7
    New Zealand
    Default HSERIN HSEROUT - Baud rate help
    Am having significant problems trying to transmit some data.
    I'm using some wireless transceivers as found here: http://www.littlebirdelectronics.com...nsfer-x-2.html
    they are supposed to be 'transparent' to and should just replace a cable. They are set up by default to be 9600bps.
    I've hooked them up to a couple of micros and run a scope on them. I cant really figure out whats going on.
    The number I'm sending out is 100 so = 1100100
    The input to the transmitter & receiver output timings listed below
    (first column transmitter input - second column receiver output)
    L 1.25ms L 0.93ms
    H 0.42ms H 0.1ms
    L 0.83ms L 0.82ms
    H 0.83ms H 0.2ms
    L 0.42ms L 0.42ms
    I figure either the output baud of my PIC isnt 9600 so the transmission is getting skewed or maybe it's inverted? The line on both starts and finished high.
    Have done comms just a couple of times before but never fully grasped the concepts.
    transmitter code:
    'pic16f722
    DEFINE HSER_BAUD 9600		'Set Baud rate to 9600bps
    DEFINE HSER_BITS 9		'Set to 9 bit mode
    DEFINE HSER_EVEN 1		'Set Even Parity
    DEFINE HSER_CLROERR 1 		'Clear overflow error automatically
    DEFINE HSER_TXSTA 20h       'Set receive register to TX en
    define HSER_SPBRG 25
    DEFINE HSER_SPBRGH 1
    INTCON = 0 			'Disable interrupts
    TRISB = %00000100 		'SET PORTB RB2(RX) as input, others to OUTPUT
    TRISA = %00000000 		'SET PORTA AS OUTPUTS
    ADCON0 = %0110010    'disable
    ADCON1 = %1000000
    TRISA= %00000000     'Set all to outputs
    ANSELA= %00000000	 'Set all to digital
    TRISB= %00000111   	 'set buttons as input
    ANSELB= %00000000    'all digital
    TRISC= %00000000     'Set PortC all outputs
    SSPCON= 0               'disable spi
    CPSCON0 = %00001101  'Cap sense off
    porta = 63
    PAUSE 1000
    LeftBtn Var PORTB.1
    RiteBtn Var PORTB.0
    StopBtn VAR PORTB.2
    RadioEn var PortC.5
    B0      VAR BYTE
    TXdata  var byte
    clear
    B0 = 1
    startloop:
      b0 = b0*2
      porta = b0
      if b0 > 60 then start
      goto startloop
      radioen = 1
    Start:
        txdata = 100
        hserout [txdata]
    goto start
    and receiver code:
    @ __config _CONFIG1, _XT_OSC & _WDT_ON & _LVP_OFF & _CP_OFF & _MCLR_OFF
    'pic16f88
    ADCON0 = %00000000      'ADC Disabled
    CMCON = 7
    ANSEL = 0
    DEFINE HSER_RCSTA 90h       'Set receive register to receiver en
    ANSEL = 0 			'ALL DIGITAL
    CMCON = 7 			'COMPARATORS OFF
    'Variables
    MtrPwr  Var PortA.1
    ServoEn VAR PortB.3     '0 = enabled
    RadioEn VAR PortB.4     '1 = enabled
    RXdata  var byte        'received data frm tx
    b0      var byte
    PortA = 0
    PortB = 0
    ServoEn = 1
    radioen = 1
    BCMDATA VAR BYTE[12]		'Define BCMAADATA as a byte array (12 Bytes)
    Count1 VAR BYTE			'Define Count1 as a byte variable (Used in For/Next Loops)
    CheckSum VAR BYTE		'Define CheckSum as a byte variable
    for b0 = 0 to 20
    toggle mtrpwr
    next b0
    mtrpwr = 0
    clear
    Commloop: 				'Start of Communications Loop
        HSERIN [Rxdata]		'receive data
        if rxdata = 100 then
            mtrpwr = 1
            pause 10000
            mtrpwr = 0
    goto commloop
    I would really appreciate some help from you wonderful people, I've just started back into PBP and every aspect of my first project back is turning to custard. Many Thanks in advance
    New Zealand
    I just noticed in the transmission the shortest bit is 0.42ms, that equates to around 2400bps and in the receiver output the shortest is 0.1ms which equates to 10,000bps - tho I didnt measure it that accurately so probably 9600. If it works like that - why is my PIC sending out data at 2400bps?
    It looks like your transmitter is set to 2400, but your receiver is set for 9600 baud.
    check out:
    I like using PicMultiCalc. It can be found here: http://www.picbasic.co.uk/forum/cont....-PICMultiCalc
    Then I can just paste it into my code. Here is one for 2400 baud, and one for 9600 baud.
    DEFINE HSER_SPBRG 25  ' 2400 Baud @ 4MHz, 0.17%
    DEFINE HSER_SPBRG 25  ' 9600 Baud @ 4MHz, 0.16%
    http://www.scalerobotics.com
    New Zealand
    Thanks - it works a treat now! Really appreciate your help. That Mister E is a clever fello
    New Zealand
    Default Sorry guys I'm back
    The PIC16f722 was doing funny things, in desperation I threw it away and went back to the trusty 16F88 however this is not working for me either.
    The PicKit 3 I bought was driving me mad also, so it's back to the ETT programmer and PicKit 2 software.
    It compiles and assembles ok, but it will not program. The programmer says "Verification of Configuration Failed" It programs fine if I get rid of anything to do with HSEROUT the defines and the command.
    But the instant I bring in an HSEROUT command it will fail.
    Here's the code:
    'pic16f88
    TRISB = %00001111 		'SET PORTB RB2(RX) as input, others to OUTPUT
    porta = 63
    PAUSE 1000
    'LeftBtn Var PORTB.1
    'RiteBtn Var PORTB.3
    'StopBtn VAR PORTB.0
    'RadioEn var PortB.4
    B0      VAR BYTE
    B1      var byte
    B2      var byte
    TXdata  var byte
    Direction var byte
    LEDPtrn var byte
    WakeVar var byte
    MtrPwr  var bit
    clear
    porta = 0
    start:
    txdata = 100
    hserout [txdata]
    goto start
    I'm going completely nuts over this and I think I'm about to get fired for being so useless. Please help
    I do not know what is going on with the HSEROUT but you may want to correct something else. Who knows, maybe it will solve the other.
    RA5 can only be an input. You have.
    Then this
    porta = 63 = 00111111
    malc-c's Avatar
    malc-c Guest
    On the 18 pin device it appears that RA7 is also input only !
    http://ww1.microchip.com/downloads/e...doc/30487c.pdf
    Also, and whilst no expert on your settings you have
    porta = 63
    PAUSE 1000
    you have set PORTB as output apart from RB2 but appear to have buttons which are normally inputs ( taking pin high or low) on RB1, RB3, RB0 and RB4 ?, but appear to have set it correctly with TRISB = %00001111
