IR Spotlight
Results 1 to 7 of 7
Thread: IR Spotlight
    Red face IR Spotlight
    Good day
    I just want to find out how would I build an Infrared spotlight to use with my Sony DCR-HC28E
    camcorder to see at night?
    Can I just purchase a couple of IR LEDs and connect them to a power supply, or is it more difficult than that?
    I guess it would depend on the distance and spread at that distance.
    This may give you an idea
    http://www.lasertagparts.com/mtoptics.htm
    Thank you very much for your feedback!!
    If I need to connect eg 10 LEDs to work together in a spotlight, will it work if I connect them in parallel to a 5v power supply and then add a magnifying glass as a lens?
    If the power supply will handle the amps then yes.
    Thank you very much!!
    Mar 2006
    China
    Default and a lens
    Donīt forget to get a lens and put infront of the LEDs. You can try using high intensity RED led and they will give you a good estimation of the final result.
