Measuring audio phase shift through a circuit with a PIC
Results 1 to 40 of 50
Threaded View
  1. #15
    Mar 2009
    Ok, this seems to work (ie it allows a 'main body' of program to run, with an interrupt handler)....
    Comp1Time       var  word
    Comp2Time       var  word
    phase_shift     var  word
    c               var  word
    dummy           var word
    T1CON.0= 1  'start timer
    Comp1Time = 0 'clear down Comp1Time, prior to starting.
    comp2Time = 0  'clear down Comp2Time, prior to starting
    PIR2.5 = 0    'Clear the Comp1 interrupt flag
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System  PO90OOO9
            INT_Handler   CMP1_INT,  _Comp1_Int,   PBP,  yes
    @ INT_ENABLE  CMP1_INT     ; enable Comparator 1 interrupts
    Top:
            c = 3600
            dummy = comp2time * c
            phase_shift  = DIV32 comp1time
            HSEROUT ["  C1=",dec Comp1Time,9,"  C2=", dec comp2time,9, "phase_shift=", dec phase_shift/10,".",dec phase_shift//10, 13, 10]
            goto top
    Comp1_Int:
            PIR2.5 = 0
        Loop1:
            WHILE PIR2.5 = 0
            GOTO Loop1
            WEND
            TMR1H = 0
            TMR1L = 0
            PIR2.5 = 0
            Comp1_count:
            WHILE PIR2.5 = 0
            goto Comp1_count
            wend
            Comp1Time.Highbyte = TMR1H
            Comp1Time.Lowbyte = TMR1L+2
            TMR1H = 0
            TMR1L = 0
            PIR2.6 = 0
            'HSEROUT [dec Comp1Time,13, 10]
            Comp2_count:
            WHILE PIR2.6 = 0
            goto Comp2_count
            wend
            Comp2Time.Highbyte = TMR1H
            Comp2Time.Lowbyte = TMR1L+6
            TMR1H = 0
            TMR1L = 0
            if comp2time> comp1time-23 then comp2time = 0
            'HSEROUT ["C1=",dec Comp1Time,9,"C2=", dec comp2time, 13, 10]
            PIR2.5 = 0
    @ INT_RETURN
    The actual final phase calculation jitters about a bit (but I suspect that down to the somewhat jittery quality of my audio input signal into the PIC comparators)...
    Now I'm sure there are more efficient ways of doing the above - but for now, it work s& I'm chuffed!
    The actual final phase calculation jitters about a bit (but I suspect that down to the somewhat jittery quality of my audio input signal into the PIC comparators!)...
    Listen guys - a great collaborative effort there - I can't thank you all enough....hopefully this gives a bit of closure to a long & painful saga!
