Measuring audio phase shift through a circuit with a PIC
Results 1 to 40 of 50
Threaded View
  1. #12
    Mar 2009
    Ok, success (of sorts)
    By keeping it simple, this code works (many thanks to Paul, whose code sample I used, albeit in McSpank-esque form here)...
    PIR2.5 = 0    'Clear the Comp1 interrupt flag
    Comp1Time = 0
    Main_Loop:
            WHILE PIR2.5 = 0
            GOTO Main_Loop
            WEND
            TMR1H = 0
            TMR1L = 0
            PIR2.5 = 0
            Comp1_count:
            WHILE PIR2.5 = 0
            goto Comp1_count
            wend
            Comp1Time.Highbyte = TMR1H
            Comp1Time.Lowbyte = TMR1L
            TMR1H = 0
            TMR1L = 0
            PIR2.6 = 0
            'HSEROUT [dec Comp1Time,13, 10]
            Comp2_count:
            WHILE PIR2.6 = 0
            goto Comp2_count
            wend
            Comp2Time.Highbyte = TMR1H
            Comp2Time.Lowbyte = TMR1L
            TMR1H = 0
            TMR1L = 0
            HSEROUT ["C1=",dec Comp1Time,9,"C2=", dec comp2time, 13, 10]
            PIR2.5 = 0
            goto Main_Loop
    ie the C2 count decrements nice & smoothly (& below 336 - yay!) & totally in line with the amount of phase lag....
    (green trace is comp1 - non lagged, yellow trace is into comp2 & lagged a miniscule amout)
    .....I can get all the way down to 13-14(ish) below which the C2 count gets very jittery (ie successive counts eg 5, 11, 6, 12, 5, - you can see some 19s in that stream above)....but a comp2 count of 13 @1kHz is granular enough for me (accuracy to within 0.936 degrees @1kHz). I'm elated...*BUT*
    Quite clearly my original way is causing some issues (p& almost certainly to do with my poor sequence &/or coding), so if this way of doing it works, how can I integrate it into my main program?
    My first attempt just now failed...
    Here's the screen output...
    C1=4909 C2=13
    C1=4903 C2=13
    C1=4909 C2=13
    C1=4909 C2=13
    hello
    C1=4903 C2=13
    C1=4909 C2=13
    ie that C1 count has dropped?!! (even though the incoming frequency has remained at 1Khz)
    here's what I did (disclaimer: I didn't know how to get the main body of program to 'jump' to to the interrupt handler when Comp1 interrupted, so I deferred back to DT's method as the initial 'trigger')...
    Comp1Time       var  word    ' used to amalgamate TMR1 High & Low Bytes.
    Comp2Time       var  word
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System  PO90OOO9
            INT_Handler   CMP1_INT,  _Comp1_Int,   PBP,  yes
    T1CON.0= 1  'start timer
    Comp1Time = 0 'clear down Comp1Time, prior to starting.
    comp2Time = 0  'clear down Comp2Time, prior to starting
    @ INT_ENABLE  CMP1_INT     ; enable Comparator 1 interrupts
    Comp1Time = 0
    Comp2Time = 0
    'Main body of Code****************************************************************
    hserout ["hello", 13, 10]
    pause 20
    goto Main
    '**********************Comp1 interrupt handler*********************************************************
    Comp1_Int:
    Comp1_Loop:
            WHILE PIR2.5 = 0
            GOTO Comp1_Loop
            WEND
            TMR1H = 0
            TMR1L = 0
            PIR2.5 = 0
            Comp1_count:
            WHILE PIR2.5 = 0
            goto Comp1_count
            wend
            TMR1H = 0
            TMR1L = 0
            PIR2.6 = 0
            Comp2_count:
            WHILE PIR2.6 = 0
            goto Comp2_count
            wend
            TMR1H = 0
            TMR1L = 0
            PIR2.5 = 0
    @ INT_RETURN
