Thanks Jerson....I'll study that later (it's 2.15am here in Lodnon!)
Actually, this looks like it might have some signs of doing what I want...
What's getting me bogged down is something as simple as setting my config correct for a 20Mhz external resonator. (the first time I've used an external clock)Code:'Comparator1 Interrupt handler+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Comp1_Int: @ INT_DISABLE CMP1_INT Comp1Time.Lowbyte = TMR1L 'puts the timer's low byte in MyTime's lower 8 bits Comp1Time.Highbyte = TMR1H 'puts the timer's high byte in MyTime's upper 8 bits TMR1H = 0 'Set the high part of the timer value to 0 TMR1L = 0 'Set the low part of the timer value to 0 @ INT_ENABLE CMP2_INT 'Comp1Time =Comp1Time +4 'dummy = b * c '5,000,000 'frequency = div32 Comp1time 'frequency =frequency/2 'HSEROUT ["mytime = ", dec mytime,9, dec frequency/10,".",dec frequency//10,"Hz",13, 10] @ INT_RETURN 'Comparator2 Interrupt handler+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++ Comp2_Int: @ INT_DISABLE CMP2_INT Comp2Time.Lowbyte = TMR1L 'puts the timer's low byte in MyTime's lower 8 bits Comp2Time.Highbyte = TMR1H 'puts the timer's high byte in MyTime's upper 8 bits TMR1H = 0 'Set the high part of the timer value to 0 TMR1L = 0 'Set the low part of the timer value to 0 @ INT_ENABLE CMP1_INT @ INT_RETURN
I'm putting a 1Khz test signal into comparator1 input pin- the handler it's registering 2500 timer1 'counts' between successive compartor1 interrupts - that doesn't seem correct for a 20Mhz external clock?
at 1Khz, the actual physical time between interrupts should be 1ms - & I'm seeiing a count of 2500 for comparator 1 interrupts.....
therefore 1ms divided by 2500 is 0.0000004 seconds ....or in frequency is 2500000Hz (2.5Mhz - that's not 20Mhz???).
here's my settings...
what am I setting wrong? (I'm using MPASM assembler)Code:@ __CONFIG _FCMEN_OFF & _HS_OSC & _WDT_OFF & _MCLRE_OFF & _CP_OFF & _IESO_OFF & _BOR_OFF & _PWRTE_OFF DEFINE OSC 20 ' set Oscillator at 20Mhz. OSCCON.0 = 0
