Measuring audio phase shift through a circuit with a PIC
Results 1 to 40 of 50
Threaded View
  1. #11
    Bombay, India
    Yes, you need to track overflows in your code - too low frequency. Of course, the same may not be true for the phase. Tracking the overflow needs to be done. I did not have to use such a thing since my frequency in was fixed at 50Hz. However, I can propose, you could use the timer start/stop method and track the timer overflow to indicate a very low frequency or too large values of time coming in.
    Possible implementation
    Comp1 int
    if T1 has overflowed, you have yourself an error condition here. Freq Too Low
    FreqCounts = T1
    T1 = 0
    Comp2 int
    PhaseCounts = T1
    Again, the 'stick in the mud' is T1 being set to 0. But, here, you get your freqcounts and phasecounts directly.!!!
    The time from one zero crossing (T1=0) to the next zero crossing on the same Comparator is the frequency counts. Read this, check for overflow and Set T1 = 0.
    The time from the zero crossing of Comp1 to the zero crossing of Comp2 is the phase counts.
    Oh, and you need to run your PIC at 20MHz just so you have more time in your ISRs. A helpful suggestion would be to write your ISR in ASM no matter how difficult it seems; PBP adds overhead to the code you write and its better to exit the ISR as quickly as you can to let other blocks of code to run.
