Measuring audio phase shift through a circuit with a PIC
Results 1 to 40 of 50
Threaded View
  1. #5
    Mar 2009
    Ok. I've hit a wall - & I can't get passed it - I need a leg up!
    Te recap, I'm using a PIC to measure frequency (80Hz thru 1.4Khz) by counting the number of clock pulses between successive comparator interrupts. It works well.
    I now need to measure phase shift .....but how to actually use the PIC hardware options available, to detect the amount of clock pulse between the non phase shifted signal & phase shifted signal's leading edges?
    Here's a schematic of my test circuit...
    I detect frequency as follows...
    DT's Comp1 interrupt - start a timer
    DT's Comp1 interrupts again - stop a timer.
    so want to add in phase shift detect by bringing in another timer and measuring the clock counts until the second (lagging) signal's leading edge arrives, therefore the enlarged picture....
    start another timer
    second (phase shifted) signal's leading edge arrives - stop the other timer.
    here's the bit I'm using for frequency detection (for clarity I've ommited the config/registers as this bit works)...
    INCLUDE "DT_INTS-14.bas"     ' Base Interrupt System  PO90OOO9
            INT_Handler   CMP2_INT,  _Comp2_Int,   PBP,  yes
    @ INT_ENABLE  CMP1_INT     ; enable Comparator 1 interrupts
    @ INT_ENABLE  CMP2_INT     ; enable Comparator 1 interrupts
    Comp1Time = 0 'clear down Comp1Time, prior to starting.
    comp2Time = 0  'clear down Comp2Time, prior to starting
    'Main body of Code*********************************************************************************************
            HSEROUT ["comp2=", dec comp2Time,9,"comp1=", dec Comp1Time, 13, 10]
            goto Main
    'Comparator1 Interrupt Handler+++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
    Comp2_Int:
            if T1CON.0= 0 then 'if timer1 is not running then...
            TMR1H = 0 'Set the high part of the timer value to 0
            TMR1L = 0 'Set the low part of the timer value to 0
            T1CON.0= 1  'start timer
            T1CON.0= 0  'stop timer1
            Comp2Time.Lowbyte = TMR1L            'puts the timer's low byte in Comp1Time's lower 8 bits
            Comp2Time.Highbyte = TMR1H           'puts the timer's high byte in Comp1Time's upper 8 bits
            Comp2Time = Comp2Time
    @ INT_RETURN
    but when I add in a little bit extra (bolded below in red), the HSEROUT chokes....
            goto Main
    Comp2_Int:
            T1CON.0= 1  'start timer1
            TMR2 = 0 'clear tmr2
            T2CON.2 = 1  'start tmr2
    @ INT_RETURN
    Comp1_Int:  ' store the amount of clock pulses elapsed since routine above finished
            T2CON.2 = 0
            COMP1TIME = TMR2
            TMR2= 0
    @ INT_RETURN
