H-Bridge control DC motor
Results 1 to 9 of 9
    one thing can be done... take multiple ADC reading and look at them after. if one is very different from the other, discard them/him and do an average of the others.
    Maximum current driving of your 30V supply may also be the cause. If your motor ask for more or close to 1A when you apply the power on, your power supply can fall in a kind of current protection wich really drop the voltage or cause some spike. Depending on how good he is. In general motor will ask more current on the few uSec the power is apply on. The spec of the motor will tell you the average needed current without any load to drive and while he's already running for a few mSec or Usec. That has to be consider. Safe when you supply is 2-3 time higher than the current motor need.
    Porto - Portugal
    Hello all
    I don't know if this get in time yet, but....
    Paul I hope that your workbench power supply has two different transformers, one for each power rail otherwise you maybe inducing noise right from the transformer.
    In a machine I've worked with which has a vertical platform and the position was obtained from a pot I needed to take the wires away from the pot from those who controls the power (high induction through the wires) and as mister_e wrote it is a good practice to take a decent set of readings and discard the ones that goes out of the scale, in my machine the use of capacitor with the pot proved to be a bad choice so I discarded the capacitor and used a shielded cable (the pot was 2 meters away from the PIC16F877A).
    Hope that you solved your problem
    nomada
    Paul F's Avatar
    Paul F Guest
    Default H-Bridge
    Hello Normanda,
    I think I have tried everything. Seperate bench supplies, Heavy wires, inductive filters in the supply lines, large resevoir cap 10,000uF.
    The system is working now. The spikes on the supply was caused when the L6203 was being switched on and off, (pulsed driven).
    I now only read the adc during the period when the L6203 is not driven and the results so far appear to be acceptable.
    Many thanks for your reply especially the hint on screend cable to the pot and everyone else who offered their help and advice.
    Many thanks to all
    Paul
  1. Replies: 19
    Last Post: - 27th May 2010, 03:56
  2. DC motor parameters estimation !
    By iugmoh in forum General
    Last Post: - 6th June 2008, 17:29
  3. dc motor control using pic16f876
    By parinshah in forum General
    Last Post: - 1st April 2006, 15:29
  4. H-Bridge control DC motor
    By Paul F in forum General
    Last Post: - 2nd March 2005, 21:04
  5. HPWM Motor Control
    By hughgoodbody in forum General
    Last Post: - 30th January 2005, 22:41
