I am not sure if you have mentioned this before. Are you using a voltage regulator? Where are you getting your supply voltage from?
I have tried 2 difference sources. Firstly a computer power supply's 5v rail, and ive also tried the 5v source on the pickit2. No regulator.
Quote Originally Posted by malc-c View Post
To be honest I'm finding it hard to work that PCB out - I guess the copper is the top layer as it's surface mount ?...
The blue is bottom layer - all surface mount components are on the bottom layer. The through-hole components are on the top layer. Even though it looks like components are on top of each other, they are actually on opposite sides of the board.
I realise that the PCB isn't self explanatory, sorry.
Quote Originally Posted by languer View Post
A few pointers:
I will try the things you suggested and post back.
