Just to be sure, I just added another 0.1uF cap directly across the supply pins of the pic and it didnt help.
I've also turned off MCLR, but also no luck.
I've also just tried replacing the PIC but same issue.
I'm stumped.
I'm stumped.
OP should read:
Acetronics, can you edit it? I dont seem to be able to any more.I'm running an 18f1320 at 40mhz using a 10mhz crystal with PLL enabled.
The oscillator worked fine on a breadboard, but when I built a PCB for it, it worked for a while and then stopped working.
It works again for a little while if I melt the solder points for the oscillator with my soldering iron, but 20 mins later it stops working again.
Ive attached the PCB design. Anyone have ideas?
