Serin after instant interupt?
Results 1 to 13 of 13
    Default Re: Serin after instant interupt?
    Say that you use the low-going edge as an interrupt trigger.
    Then you start the Serin command that waits for the negative going edge. My guess is that it will loose the first byte and then will receive next one.
    So, I would make two same characters as a start, one will be lost, the second will be the wait character, and then start getting the payload.
    I don't have any control over the transmitting device.. So I can't add bytes.
    OK
    You could also manually read the RCREG directly.
    I'm using software serin2 on a non usart pin.. My hardware UART are taken.
    Any chance to use a PIC with two USARTs?
