Compilation errors
Results 1 to 14 of 14
    Aug 2010
    Default Compilation errors
    Hi.
    I'm trying to learn how to program PIC's, using a swedish education material......And I have sucessfully made a few programs.
    When I tried to use ICSP, I got some problems and I suspected that my PBP was too old, so I upgraded to 2.60.
    Now I get compilation errors every time, even when I try to compile old programs that worked before!
    ERROR Line 11: LOOP without a matching DO. (blink2.pbp)
    ERROR Line 15: Syntax error. (blink2.pbp)
    loop: HIGH PORTB.0 'Tänd lysdiod (line 11)
    PAUSE 100 'Vänta 100 ms
    LOW PORTB.0 'Släck lysdiod
    PAUSE 900 'Vänta 900 ms
    GOTO loop 'Hoppa tillbaka till loop (line 15)
    What's up? Am I doing something wrong/different?
    malc-c's Avatar
    malc-c Guest
    I'm hoping others will correct me, but I beleive LOOP is recognised as a command rather than a label in 2.60. Try changing LOOP: for MAIN:
    With the new version of PBP LOOP is a command.
    Anyplace you have LOOP as a label will give trouble.
    Try changing the LOOP labels to LOOP1.
    Malcolm beat me to it
    Aug 2010
    So it really IS a software version problem!
    Thanks guys, this was driving me nuts!
    My education material is obviously based on the older software, I wonder if I should go back to 2.50?
    Quote Originally Posted by mikebike View Post
    Easy to use the replace function in MCS just replace Loop with another word or spelling like 1LOOP, or ALOOP or any other word which makes sense to you, that is not already a restricted word, (there is a list of those words in the manual). I think they made this change in PBP to make it more in keeping with " C " conventions, since many people code in either.
    ver. 2.6 supports chips that 2.5 does not, and has some REAL BONUS FEATURES over 2.5 .
    Aug 2010
    Yes, loop1 works fine.
    I think I must download the manual for 2.60......
    You get the manual when you purchase PBP 2.60.
    It is not available for download.
