strange problem with HSERIN
Results 1 to 17 of 17
    Aug 2010
    The USART RX pin should definitely idle high, but this routine has some major issues;
    BEGIN:
       For K = 240 TO 240  ' <-- BIG problem here
        teller = teller + 1
        ADRESS = K
        AANTAL = 1
        buffero(K) = teller  ' <-- there is no buffero(240)
        GoSub WEGSCHRIJVEN
        PauseUs 200
        ADRESS = K
        AANTAL = 1
        GoSub OPHALEN
        IF OK = 1 Then
         lcdbufO(K) = bufferi(K) ' <-- same issue here
         LCDBUFI(K) = BUFFERO(K) ' <-- and here
         GoSub LCD
         OK = 0
        GoTo HIER1
        EndIF
       LCDBUFO(K) = 0
       LCDBUFI(K) = 0
       GoSub LCD
    HIER1:  Next
    K = 240, but your largest array variables are only 6 bytes. I.E. buffero(0) to buffero(5) would be the last byte available in your buffero array.
    I tried to change the For K = 240 TO 240 to For K = 0 TO 5 , but it does not make any difference.
    The chip still keeps running VERY slow (like 25 seconds startup time) when I'm using the HSERIN command.
    The RS232 schematic is ok, I'm using the same for other PCB's with 16f887 and 16f882 chips where it works fine.
    Also changing the bit TRISG<2> = 1 does not solve this problem.
    Any more suggestions?
    Oct 2003
    holland
    I did some tests with that chip and also using a rs485 chip to test. You talked about rs232 and a direction (TX_ENABLE) and when I look at the code I think it's RS485, but that is not an issue.
    I also discovered that indeed the chip will not startup when using HSERIN and the RX pin of the uart is high.
    I put a 10K resistor from the RX pin of the picchip to ground and now the program is starting up normaly.
    I hope it will help you.
