The USART RX pin should definitely idle high, but this routine has some major issues;
K = 240, but your largest array variables are only 6 bytes. I.E. buffero(0) to buffero(5) would be the last byte available in your buffero array.Code:BEGIN: For K = 240 TO 240 ' <-- BIG problem here teller = teller + 1 ADRESS = K AANTAL = 1 buffero(K) = teller ' <-- there is no buffero(240) GoSub WEGSCHRIJVEN PauseUs 200 ADRESS = K AANTAL = 1 GoSub OPHALEN IF OK = 1 Then lcdbufO(K) = bufferi(K) ' <-- same issue here LCDBUFI(K) = BUFFERO(K) ' <-- and here GoSub LCD OK = 0 GoTo HIER1 EndIF LCDBUFO(K) = 0 LCDBUFI(K) = 0 GoSub LCD HIER1: Next
