strange problem with HSERIN
Results 1 to 17 of 17
    Aug 2010
    Well, thats the strange thing about this.
    It does not matter if I jump to the routine or not.
    It only matters if I comment out the HSERIN command.
    Can It be something with the initialisation of the chip and the USART?
    That is strange. Can you post more information as mentioned above?
    -Bruce
    tech at rentron.com
    http://www.rentron.com
    malc-c's Avatar
    malc-c Guest
    I had issues with serial comms when moving code from an 16F877A to an 18F4580. Turns out it was due to the crystal. I had been using a 20Mhz with an OSC 48 defined - when used with the 18F the program would still run but serial comms at 115200 was garbage - following advice from forum members I changed the xtal to 12Mhz and ran with the HS_PLL defined and same OSC defined and that worked for me.
    As Bruce stated, post up your complete code or at least the defines and what Xtal you are using
    Aug 2010
    I will post the code tomorrow morning, I do not have it available where I'm at the moment.
    Aug 2010
    This is the program code. the hserin2 is only used. I'm using a 20Mhz OSC.
    the tx_enable is connected to TG0 (pin5)
    the rx2 is connected to RG2 (pin7)
    the tx2 is connected to RG1 (pin6)
     'PIC18F85J11 mainboard grafisch display
       DEFINE HSER_TXSTA 24H
       DEFINE HSER_RCSTA 90H
       DEFINE HSER_SPBRG 4
       DEFINE HSER_CLROERR 1
       DEFINE HSER2_TXSTA 24H
       DEFINE HSER2_RCSTA 90H
       DEFINE HSER2_SPBRG 4
       DEFINE HSER2_CLROERR 1
       'DEFINE ADC_BITS  8
       'DEFINE ADC_CLOCK  3
       'DEFINE ADC_SAMPLEUS 50
       DEFINE OSC 20
       DEFINE LCD_DREG PORTE
       DEFINE LCD_DBIT 0
       DEFINE LCD_RSREG PORTF
       DEFINE  LCD_RSBIT 4
       DEFINE LCD_EREG PORTG
       DEFINE LCD_EBIT 4
       DEFINE LCD_BITS 8
       DEFINE LCD_LINES 2
       DEFINE LCD_COMMANDUS 2000
       DEFINE LCD_DATAUS 50
       ADCON1  = 15
       ADCON0   = 0
       CMCON   = 7
       T0CON  = %11000011
       INTCON  = %10100000
       INTCON2  = %00000100
       TRISA  = %10111111
       TRISB  = %00000001
       TRISC  = %10000000
       TRISD  = %01000000
       TRISE  = %00000000
       TRISF   = %00000110
       TRISG   = %00000000
       TRISH   = %10110100
       TRISJ   = %00000001
       INP_OUTP21 VAR PORTA.0
       INP_OUTP22 VAR PORTA.1
       INP_OUTP23 VAR PORTA.2
       INP_OUTP24 VAR PORTA.3
       INP_OUTP25 VAR PORTA.4
       INP_OUTP26 VAR PORTA.5
       XTAL_0  VAR PORTA.6
       XTAL_1  VAR PORTA.7
       INP_OUTP27 VAR PORTB.0
       IR_DATA  VAR PORTB.1
       INP_OUTP28 VAR PORTB.2
       INP_OUTP29 VAR PORTB.3
       INP_OUTP30 VAR PORTB.4
       INP_OUTP31 VAR PORTB.5
       PRG_CLK  VAR PORTB.6
       PRG_DTA  VAR PORTB.7
       INP_OUTP32 VAR PORTC.0
       RES_01  VAR PORTC.1
       RES_02  VAR PORTC.2
       SCL_ROM  VAR PORTC.3
       SDA_ROM  VAR PORTC.4
       RES_03  VAR PORTC.5
       RF_TX  VAR PORTC.6
       RF_RX  VAR PORTC.7
       RES_04  VAR PORTD.0
       RES_05  VAR PORTD.1
       RES_06  VAR PORTD.2
       RES_07  VAR PORTD.3
       INP_OUTP01 VAR PORTD.4
       INP_OUTP02 VAR PORTD.5
       INP_OUTP03 VAR PORTD.6
       INP_OUTP04 VAR PORTD.7
       D0_DISPLAY VAR PORTE.0
       D1_DISPLAY VAR PORTE.1
       D2_DISPLAY VAR PORTE.2
       D3_DISPLAY VAR PORTE.3
       D4_DISPLAY VAR PORTE.4
       D5_DISPLAY VAR PORTE.5
       D6_DISPLAY VAR PORTE.6
       D7_DISPLAY VAR PORTE.7
       DISPL_EN1 VAR PORTF.1
       DISPL_EN2 VAR PORTF.2
       RES_08  VAR PORTF.3
       DISPL_RS VAR PORTF.4
       RES_09  VAR PORTF.5
       RES_10  VAR PORTF.6
       RES_11  VAR PORTF.7
       TX_ENABLE VAR PORTG.0
       TX_RS485 VAR PORTG.1
       RX_RS485 VAR PORTG.2
       RES_12  VAR PORTG.3
       DISPL_EN VAR PORTG.4
       INP_OUTP05 VAR PORTH.0
       INP_OUTP06 VAR PORTH.1
       INP_OUTP07 VAR PORTH.2
       INP_OUTP08 VAR PORTH.3
       INP_OUTP09 VAR PORTH.4
       INP_OUTP10 VAR PORTH.5
       INP_OUTP11 VAR PORTH.6
       INP_OUTP12 VAR PORTH.7
       INP_OUTP13 VAR PORTJ.0
       INP_OUTP14 VAR PORTJ.1
       INP_OUTP15 VAR PORTJ.2
       INP_OUTP16 VAR PORTJ.3
       INP_OUTP17 VAR PORTJ.4
       INP_OUTP18 VAR PORTJ.5
       INP_OUTP19 VAR PORTJ.6
       INP_OUTP20 VAR PORTJ.7
       I  VAR BYTE
       K  VAR BYTE
       TELLER  VAR BYTE
       ADRESS  VAR BYTE
       AANTAL  VAR BYTE
       LCDBUFI  VAR BYTE [6]
       LCDBUFO  VAR BYTE [6]
       BUFFERI  VAR BYTE [6]
       BUFFERO  VAR BYTE [6]
       STARTCHAR VAR BYTE
       DATO  VAR BYTE
       DATI  VAR BYTE
       BUFF  VAR BYTE
       OK  VAR BIT
       Pause 500
       Clear
       FLAGS = 0
       LCDOut $FE,$1,  "DISPLAY"
       LCDOut $FE,$C0, "TEST"
       Pause 500
       TX_ENABLE = 1
       STARTCHAR = "$"
    BEGIN:
       For K = 240 TO 240
        teller = teller + 1
        ADRESS = K
        AANTAL = 1
        buffero(K) = teller
        GoSub WEGSCHRIJVEN
        PauseUs 200
        ADRESS = K
        AANTAL = 1
        GoSub OPHALEN
        IF OK = 1 Then
         lcdbufO(K) = bufferi(K)
         LCDBUFI(K) = BUFFERO(K)
         GoSub LCD
         OK = 0
        GoTo HIER1
        EndIF
       LCDBUFO(K) = 0
       LCDBUFI(K) = 0
       GoSub LCD
    HIER1:  Next
       GoTo BEGIN
    'SUBROUTINES
    WEGSCHRIJVEN:
       DATO = STARTCHAR : GoSub CHAROUT
       DATO = ADRESS : GoSub CHAROUT
       DATO = "W" : GoSub CHAROUT
       For I = 1 TO AANTAL
        DATO = BUFFERO(I) : GoSub CHAROUT
       Next
    OPHALEN:
       OK = 0
       DATO = "R" : GoSub CHAROUT
       PauseUs 100
       TX_ENABLE = 0
       HSerin2 1,GO,[WAIT("$"),BUFF]
       IF BUFF = ADRESS Then
        OK = 1
        For I = 1 TO AANTAL
        HSerin2 [DATI]
        BUFFERi(I) = DATI
       Next
       EndIF
    GO:
       PauseUs 50
       TX_ENABLE = 1
    CHAROUT:
       TX_ENABLE = 1
       HSerout2 [DATO]
    LCD:
       GoSub USE_LCD1
       LCDOut $FE,$80, "ADRES       1    2"
       LCDOut $FE,$94, "   3    4    5"
       LCDOut $FE,$C0, "DATA    ",HEX LCDBUFO(1),"  ",HEX LCDBUFO(2)
       LCDOut $FE,$D4, HEX LCDBUFO(3),"  ",LCDBUFO(4),"  ",LCDBUFO(5)
       GoSub USE_LCD2
       LCDOut $FE,$80, "DATA    ",HEX LCDBUFI(1),"  ",HEX LCDBUFI(2)
       LCDOut $FE,$94, HEX LCDBUFI(3),"  ",LCDBUFI(4),"  ",LCDBUFI(5)
    USE_LCD1:
           Input DISPL_EN1
           Low   DISPL_EN2
    USE_LCD2:
          Low   DISPL_EN1
           Input DISPL_EN2
    USE_BothLCD:
           Input DISPL_EN1
           Input DISPL_EN2
    HSERIN2 is only used for chips with two hardware serial ports/
    Aug 2010
    The 18f85j11 has 2 serial ports. 1 EUSART and 1 AUSART. I should be able to use this command.
    OOPPSS
    Maybe this???
    The pins of the AUSART module are multiplexed with
    the functions of PORTG (RG1/TX2/CK2 and
    RG2/RX2/DT2, respectively). In order to configure
    these pins as an AUSART:
    • bit SPEN (RCSTA2<7>) must be set (= 1)
    • bit TRISG<2> must be set (= 1)
    • bit TRISG<1> must be cleared (= 0) for
    Asynchronous and Synchronous Master modes
