gsm modem and pic communication
Results 1 to 2 of 2
    shani_developer's Avatar
    shani_developer Guest
    Default gsm modem and pic communication
    hi everybody
    i am my my project on gsm based controlling system
    i have done simulation using proteus isis and it is working properly i have attached sony ericsson t290 ia can send and receive sms using simulation but when i made hardware it can only send but cant receive i use rsout and rsin commands for sending and receiving sms. but the problem is that the gsm phone not giviing any responce. i used 12mhz crystal and 9600 baud rate then i tested the hardware using hserin and hserout commands and test the circuit but still it is not giving any responce in hardware i used max 232 between pic and gsm modem.
    Device 18F4520
    DEFINE OSC 12
    ' Set transmit register to transmitter enabled
    DEFINE HSER_TXSTA 24h
    DEFINE HSER_RCSTA 90h
    DEFINE HSER_SPBRG 77 '.16% error
    DEFINE HSER_CLROERR 1
    DEFINE HSER_BAUD 9600
    SPBRG=77
    TRISC=%10111111
    BAUDCON.3=1
    SMS: 'this is the SMS commands routine in order to send an SMS
    HSerOut ["AT" ,13] 'set modem speed to 9600 baud
    HSerIn 3000, SMS, [Wait("OK")]
    Print At 1,1,"working" 'in order to test whther it is executing hserin command
    but the phone still not responding
    please solve this problem
    As a first step I would recommend to study the AT commnads of the specific phone.
    Maybe it needs something at the beginning to enter AT command mode.
    Then, please, DO connect the phone to a PC directly and test it with a Terminal program.
    After you feel confident with the phone then go for the micro controller connection.
    At this stage you do not know what the phone sends as a response. Maybe instead of 'OK' sends a 0 (zero).
