unable to access any ports
Results 1 to 5 of 5
    Default No administrator is set
    Thanks Malcolm but I am confused.
    I forgot to mention I am using MicroCodeStudioPlus. I can compile and MCSP opens the programmer and then, when I select COMPILE, I get the error message. If I close the programmer and right click it I get 'run as' with me as the normal user and provision to select some other user. There has never been another user, or administrator, so I don't know what to enter as the username
    You should be the admin then.
    Go to control panel and user accounts to see who is who.
    malc-c's Avatar
    malc-c Guest
    One other thing to try is to re-boot the netbook and go into the BIOS and make sure that (if exists) the USB ports are enabled / active.
    One other possible cause is that the programmer is looking for a serial com pot, which on most netbooks don't exists - have you double checked the config settings of the programmer ?
