Try right clicking on the programers EXE and select "run as administrator" to see if that helps.
Thanks Malcolm but I am confused.
I forgot to mention I am using MicroCodeStudioPlus. I can compile and MCSP opens the programmer and then, when I select COMPILE, I get the error message. If I close the programmer and right click it I get 'run as' with me as the normal user and provision to select some other user. There has never been another user, or administrator, so I don't know what to enter as the username
You should be the admin then.
Go to control panel and user accounts to see who is who.
One other thing to try is to re-boot the netbook and go into the BIOS and make sure that (if exists) the USB ports are enabled / active.
One other possible cause is that the programmer is looking for a serial com pot, which on most netbooks don't exists - have you double checked the config settings of the programmer ?
