A header wizard
Results 1 to 40 of 230
Thread: A header wizard
    Thanks again Paul.
    I am looking forward to it.
    Feb 2010
    USA, New England
    Default PBP Header Wizard v0.1, Build #5
    Hi All,
    Got the new version for you to try out (attached).
    Incidentally, from now on I'll just keep updating this file with the latest version.
    There are now two files within the zip file. Jut unzip these to the same folder. No paths to MPASM or PBP are required. It will create an ini file (again in that same folder) that currently just retains the last PIC selected.
    If you've followed the thread this far you should be able to figure out how to work it. There are extra tabs that appear (Comparator, USART, etc.) that don't do anything yet other than appear when appropriate for the selected PIC. The output is rough but accurate, I believe...
    Please let me know any errors, bugs, problems, or inconsistencies, you run into. I'll work on any of these that show up over the next few days then dive back into comparator setup.
    Best Regards,
    Paul
