Another question. Do we need the dependency on PBP files? I ask this because I don't know how many machines I am allowed to install PBP on (I assume 1). I use at least 2 daily, 1 at work and 1 at home. So I can't run your wizard at work cuz PBP is installed at home.
Now you may be asking yourself, Why do you need to create a header without PBP installed? Heres my reason, I often find time to work on stuff at work in small bits. So I may start a new project at work and tote it back and forth on a USB drive. Testing will be done at home, but I can still work on chunks of code at work. Make sense?
