A header wizard
Results 1 to 40 of 230
Thread: A header wizard
    Feb 2010
    USA, New England
    Thank you Dave (and Bert). I might take tonight off however...
    Darrel T: Can I include your "All Digital" as well?
    No promises on the DT Instant Interrupts configurator. Guess I'm the last PBP guy who hasn't used it! I'll add it to the list.
    Best Regards,
    Paul
    You can not... You are the only one working
    Quote Originally Posted by prstein View Post
    There's really nothing to configure with AllDigital.pbp
    It's either included or not.
    I guess you could add a single checkbox.
    Added: And maybe another checkbox for DEFINE SHOWDIGITAL 1
    Feb 2010
    USA, New England
    Hello Darrel,
    That was similar to what I had in mind. With permission, I'd put a copy of ALLDIGITAL in the installation folder and when the "All Ports Digital" checkbox was checked it would add
    include "[PBPHW Install directory]\alldigital.pbp"
    Of course I could also just parse the stuff myself but that's extra work...8^)
    Best Regards,
    Paul
    I will say having the include lines for "alldigital" and "instants" would be OK. But leave the actual files upto the user to get from Darrel's site. That way the Wizard will not have to worry about upgrades. Maybe have comments added to the header with the URL to Darrel's repository if they are used???
    Or local file if there is not always available a network connection.
    Aug 2010
    Maryland, USA
    Paul v0.1 build 2 download seemed to be build 1. did IU mess up or is the wrong file posted?
    -Bert
    Aug 2010
    Maryland, USA
    Another question. Do we need the dependency on PBP files? I ask this because I don't know how many machines I am allowed to install PBP on (I assume 1). I use at least 2 daily, 1 at work and 1 at home. So I can't run your wizard at work cuz PBP is installed at home.
    Now you may be asking yourself, Why do you need to create a header without PBP installed? Heres my reason, I often find time to work on stuff at work in small bits. So I may start a new project at work and tote it back and forth on a USB drive. Testing will be done at home, but I can still work on chunks of code at work. Make sense?
    -Bert
    Feb 2010
    USA, New England
    I messed up. The correct file is below, and I'll try to institute better file control...
    Best Regards,
    Paul
    Aug 2010
    Maryland, USA
    Best Regards,
    Paul
    Its my thinking, when the wizard is doing what we want it to do, the "all digital" will be tended to by default. If all the user wants is digital, the other stuff won't be turned on and the reg's will be set to use all dig. On the other hand, if the user checks all dig, but then configures the A/D, wizard will have to handle the error or the program won't work as expected. Of course, it could be set so if all dig is selected, all other options are grayed.
    have I lost my mind? again?
    -Bert
    Aug 2010
    Maryland, USA
    Best Regards,
    Paul
    HAHA, don't feel like the lone ranger. All I've done is read all about them.
    -Bert
