A header wizard
Results 1 to 40 of 230
Thread: A header wizard
    Aug 2010
    Maryland, USA
    It is so much fun to see such intrest in this. And to think, I started it. Its about time I had a useful idea - lol.
    I am working on working on learning python so I can help somehow. Don't know if I will be up to speed in time for first rev's, but at least I may be able to help maintain it.
    As for the 18xxJxx problem, my first question is how would we go about programing it without the wizard? When we know the answer to that, the wizard will just do the writing for us. I do like the idea of having the wizard "fix" the .inc file for us. That really seems like the most seemless solution. But that may be another chunk of code.
    @Dave and Paul, are your programs looking at the dir to find all the available *.inc files? So updates will just automaticlly be added?
    @Dave, If I am reading your code right, did you have to hard code all the cases for the config options?
    -Bert
    Mine is. The dir is copied to the server.
    Nope.
    file = open("%s" % subject,"r")
    text = file.readlines()
    file.close()
    for line in text:
        m = re.match(r"_", line)   # Looks for everything starting with "_"
        if m: print line, "<br>"
    So because of the "J" chips a second pass will be needed.
    Aug 2010
    Maryland, USA
    Maybe better to trigger off the "J" and have seperate routines? Or is the differance not that clear in the parts?
    -Bert
    Separate routines might be best.
    Split it up between
    16F
    18F
    18F__J
    Unless I am forgetting something that should be the three basic configs.
    Feb 2010
    USA, New England
    With great power comes great responsibility! Hope you hang in long enough to put it through thorough testing...
    I think that has now been resolved. Thanks, scalerobotics!
    Yes, that it exactly.
    For fun I've attached a screenshot of the application's current status...
    Best Regards,
    Paul
    Aug 2010
    Maryland, USA
    Quote Originally Posted by prstein View Post
    I'm here for a good while. I've been coding with just assy for about 10 years as a hobby, nothing big. Finally took the plunge to do things a bit easier and buy PBP. Enrolled in a python class starts on 9/15. Decided not to go the self taught route on this one. Too many times I start to learn a new language and quit cuz something doesn't make sense to me.
    As for the "thorough" testing, I will put it through all I can.
    Thanks for jumping on board. Looks like a nice start you have!
    -Bert
